Long or Short?
Long or Short?
Ok second post on the forum:
Thinking about pulling the trigger on an 08 F250 King Ranch but can't decide if I want a long or short bed truck. I know I will like the ride better and I can pull my future 5v'er with both... but the question is has anyone regretted the 8' or vice versa. Any help would be appreciated. Thanks
Keep in mind my 08 F450 long has a turning radius that is GREATLY improved over my 06 short. It makes handling a long bed way easier thank in previous models. I've already gotten out of tight spots, still not realizing how easy it would be with the new front end. It's amazing how these huge trucks are maneuvering.
I have a short bed, and don't pull a fiver. I really like the short box. Guthrie&co's blanket statement is worthless, much more so than a 6.75' bed . A short bed pickup works really well for a lot of things; however, in your situation and for what you're saying you want to do, I'd get an 8'.
A 6.75' bed will haul more than the vehicle's payload (of dirt/gravel for example), but for pulling a fiver the extra space is better. Accidents happen with the longer bed too, but less often and there is more room for error. The downside of the longer bed is driveability (parking for example), but honestly, that's not too much of a downside in my opinion.
My mother doesn't like driving a long bed, neither does my wife, neither does a good friend of mine's wife. There may be a pattern there
If SpeedE55's experience is indicative of most others, I'd say the 8' will definitely be better for you.
Just need to elaborate abit more I think on my last post.
A fiver needs more cab to fifth wheel hitch space between than a gooseneck would.Now I'm speaking on the majorities here.
If I were towing a 24ft open trailer gooseneck then personally I would prefer the short box.Why?Because you can actually manuever an open trailer gooseneck easier/tighter than a long box.
With a fifth wheel most all the time you have alot of over hang infront ahead of the fifth wheel.
I have a 40ft enclosed wells cargo fifth wheel and even with my long box I would hit my cab if it were not that I actually have a fifth wheel slider that gives me the clearance I need as to not damage/hit my cab when positioning my fifth wheel trailer.
The reason I still need the slider even with my longbox is because my fifth wheel trailer has a "nose cone"on the upper front of the trailer;its designed so that when traveling it's more aero than without it.
It would be like a tractor trailer towing a 48ft or 53 ft trailer without actually having that upper wind deflector above the tractor cab.
Most goosneck trailer have the ball on a post that is usually the furtherest forward item on the trailer so yes a short box would do be better for that specific setup but not so great for most fifth wheel setups..
I have a 24ft flatbed cornpro gooseneck that fits the bill better for a shortbox and if I ever just had a gooseneck only then I'd opt for a shortbox shorter turning radius when looking at overall length..
Will never own a truck with a short bed for hauling ever again. I always seemed to need a few more feet when I had a shortbed dodge. I always had to run tailgate down to fit plywood , 4-wheeler and everything else. Always had to worry about hitting the cab with a 5th wheel. If its for off roading get a shortbed. If it is for work and hauling get a long bed. I love my current long bed.
I've owned 1 short bed in my life. That was enough, It will not happen again. Back in the early 80's I couldn't afford the extra $150.00 for the long bed. I own 4 long beds right now and I don't understand the mentality of owning a short bed for any reason!! I can hardly believe a Truck MFG. would even make a short bed. If anything I would want a 10 foot bed. I have 2 CC LBs and yes, I park out in the hinter lands and I take up 4 spaces. I walk the 1/8 mile to the store front. I need the exercise.
