2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Exhaust: Why do they do it like that?
Old 03-01-2007, 07:03 PM
2001F250Crew2wdPSD's Avatar
2001F250Crew2wdPSD
2001F250Crew2wdPSD is offline
Well, I've seen this on so many other vehicles that I shouldn't be surprised to see it on my new EL.
Exhaust description:
Ford is using a very large cat on each bank which seems better than the old set up of 4 cats. Each cat discharges into a 2-1/2" OD tube, these 2 tubes merge together on the right side near the end of the tranny oil pan. The outlet of the merge is 2-3/4" back to the first joint (flex). Then the "cat back" portion of the exhaust necks down to 2-1/2" into the muffler, out of the muffler at 2-1/2" then bumps back up to 2-3/4".
I think a good exhaust will wake this engine up nicely. I think a system like Magnaflow will work well but may be a bit too loud for a family vehicle. So I may try running either a separate dump tube with a control valve or I may just use the new Aero Exhaust 3030XL with an AR30 for a little more sound deadening.
