Air Bag Suspension Kit - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-01-2007, 06:15 PM
aggiect01 aggiect01 is offline
aggiect01 is starting off with a positive reputation.
Question Air Bag Suspension Kit
I am looking to add either Firestone or Goodyear air ride helper spring kit to my F350. I carry between 1000K and 4K in the bed daily and I wanted to add some additional suspension help. Are these kits any good, where is the best place to buy. I found the Firestone on ebay for just under 300 and the goodyear for about the same. Any suggestions will be helpful.
Old 03-01-2007, 06:35 PM
Enomra's Avatar
Enomra Enomra is offline
Enomra has a good reputation on FTE.Enomra has a good reputation on FTE.
I have Ride rites on mine and I love them (Firestone)
Old 03-01-2007, 07:05 PM
diesel_dan's Avatar
diesel_dan diesel_dan is online now
FTE Addict
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
I have had the Air Lift brand on 3 trucks now and never had a problem -- I did the install myself on this latest truck and it's not tough to do, plus you do a better job than the installers will...
With that said, I've looked over the Firestone bag system after installing this last set of Air Lifts, and I must say I think they are of superior design, so if I were to do it again, I'd go with the Firestones (they use metal air fittings and heavier duty air lines for example).
I found the best price from Summit Racing, btw...
Good luck!
Old 03-01-2007, 07:18 PM
Thanks for the help. Is the basic system enough or is it better to get one with a build in compressor and other extras? Is it a pain to constantly stop at gas stations to add air? Should I just add them to the rear or is it benificial to add them to the front also.
Old 03-01-2007, 07:24 PM
marcs724 marcs724 is offline
marcs724 is starting off with a positive reputation.
I had the air lifts on my last truck. They work well and are durable. Install is easy....bolted right in. I regretted not spending the $$ on the in-cab controls. They WILL make your truck ride pretty rough empty if you leave a lot of air in them, but they are really nice if you have a trailer with a heavy tongue weight.
Old 03-01-2007, 07:34 PM
diesel_dan's Avatar
FTE Addict
I've heard of problems with the controllers/compressors that run the air lines to the gauges in the cab -- lots of leak issues. There are electronic controllers that are supposed to be much more reliable. With that said, I carry a $29 - 12 volt compressor with me -- I often use the bags to level the camper as well as any other load (make sure you keep the bag separate with seperate schrader valves), and then I just pump them back up as needed after breaking camp, etc.. I've never had a leak, so the pressure I set stays until I change it...
Old 03-01-2007, 08:08 PM
saltamontes's Avatar
saltamontes saltamontes is offline
saltamontes is starting off with a positive reputation.
helwig makes some now also
Old 03-01-2007, 10:12 PM
$239 from Summit sounds like a good deal to me. Has anyone had a problem with the Firestone kit? Is there a difference between kits for an 04 and earlier or is it the same for 05,06,07.
Old 03-01-2007, 11:01 PM
mrxlh's Avatar
mrxlh mrxlh is offline
mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.
Harley Davidson has a suspension pump for the iar ride bikes that works pretty good for pumping up the bags. Cost it right, nothing to break and small enough to fit in the glove box. I have the Firestone ride rights. Love them. I have the drill kit, if I had to do it again I would get the no drill, as the no drill kit allows you to mount any combination of 5iver hitches. The no drill kit is also only $10 more. I have seen them advertised for $259.
Old 03-01-2007, 11:07 PM
scottman70's Avatar
scottman70 scottman70 is offline
scottman70 is gaining momentum as a positive member of FTE.scottman70 is gaining momentum as a positive member of FTE.
I just installed the Firestone bags in my Ex today. Bought them from www.get-chrome.com for $226. THey are very nice! I didn't buy a compressor with mine, I drilled holes in the license plate and put the fill valves right on the license plate. Didn't have to drill the bumper that way!
Old 03-02-2007, 12:19 AM
wb6anp wb6anp is online now
wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.
Have the air lift brand love them helped the ride also installed the compressor and leveling sensor don't need to worry about air pressure or adding air. I hook up the trailer turn on the igntion and the compressor pumps it up to level.
Old 03-02-2007, 09:43 AM
Enomra's Avatar
I like Diesel Dan carry a portable air compressor in my toy hauler for airing down the bikes and for the trailer tires. My toy hauler will have a tongue weight of over 1200lbs depending on how the bikes are loaded. With about 50 psi in the ride rites the truck will sit perfectly level. To me nothing looks worse than a truck with a trailer and the back of the truck is squatted real bad. Not to say that the truck wont handle properly.
Old 03-02-2007, 12:00 PM
kenneBF250V10's Avatar
kenneBF250V10 kenneBF250V10 is offline
kenneBF250V10 is starting off with a positive reputation.
Check this place out. One of their systems are in my future, just haven't decided which one yet, stock height or lift. I'm tired of feeling like I'm riding in a tank.
http://www.keldermanairride.com/
Old 03-02-2007, 12:35 PM
how2fish's Avatar
how2fish how2fish is offline
how2fish is starting off with a positive reputation.
I went with the Firestone and the on board compressor and in cab gauge and switches. They have been installed for over 1 1/2 years with no problem and I love 'em.
Old 03-02-2007, 04:15 PM
dmgiff dmgiff is offline
dmgiff is starting off with a positive reputation.
Can these systems be installed on the front of the truck, or only on the rear?
Firestone Ride Rite - help FatOldGuy 6.7L Power Stroke Diesel 6 02-08-2016 02:35 PM
2015 F450 Firestone Air Bags southwindva 6.7L Power Stroke Diesel 9 06-22-2015 11:42 AM
Air Lift 57396 or Firestone 2535 Bounty_Hunter Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 11 02-09-2013 05:22 PM
Firestone or PacBrake Air bags Fear no Hill 6.7L Power Stroke Diesel 12 12-13-2012 10:18 PM
E350 rear air bags, Air Lift or Firestone? carrfamilynj 1968-2013 Full Size Vans 1 10-15-2011 07:26 AM
Tags
air, bag, bags, ca, custom, drw, eureka, f350, ford, headache, houston, kits, racks, suspension, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
