06 explorer - 4x4 problem... possible engagement issue?
I've got a 06 explorer with a 4x4 problem that occurs when turning. With 4x4 high on, when you make a left or right hand turn, a clunking noise occurs (the entire truck shudders)... then a grinding/rubbing noise for the duration of the turn, followed by another clunk (entire truck shudders) at the completion of the turn.
We've used 4x4 in the past with no issues. This problem arose for the first time yesterday.
Anything ideas? I want to go to the dealer with as much info as possible...
Thanks!
Thanks!
if the surface you are driving on is pavement with no snow or ice your drivetrain will bind. it is very hard on it. when in 4x4 your tires are being forced to rotate at the same speed when you turn. For example if you make a left turn your right tires need to spin faster than the left tires and on snow, ice, dirt etc... your tires are allowed to slip. Make sure it is in 4x4 auto or 2wd mode.
Originally Posted by mr.4.6
if in four hi going around corners if road is dry that is a normal condition.all 4x4 do this
I have not experienced this problem before this last snow fall.
Originally Posted by JerrySimm
If it's binding in a turn, it could very well be a CV joint on the axle. How many miles? Is it still in warranty? If so, I'd make it some dealers problem.
