I finally got my new truck. Dark stone, 4.3 axles, toyo MT tires, spray in bed liner, heated seats, power gas and brake pedals, upfitter switches, tow command package, 4X4 package with decal removed, camper package, 6 CD audiophile stereo, captains seats, long bed, super cab.
The raised grille emphasizes the sculpted sides of the powerdome hood and carries the theme to the air vents mounted on the fender just behind the crisply defined wheel arch. The vents dissipate engine compartment heat and designate the type of powertrain beneath the hood – red for diesel, black for gasoline.
The side vents will indicate gas or diesel by color. Black is gas, red is diesel. One quick look and you can see the engine type. I hear the diesel is so quiet that you can't necessarily tell it's diesel unless you pay attention.
Only problem with that is the '08 SD does come with 2 different gas engines...
I would still prefer to see the V10 Badge...somewhere on the new SD's. Humm...
Sockeye Salm -- That is one "SMART" looking SD! Very nice...
