Changed Sparkplugs Myself and Broke One in the Sparkplug Well in the Process
Originally Posted by 55wagon
Hey all,
I have an 06' with the 5.4, did they fix the problems with the plugs or should I also plan on doing it sooner. I've got 7,000 miles and was planning on changing plugs at 25-30k. I don't want to break a plug.
I tell you what guys id go ahead and get the PLUGs changed NOW. Its cheaper than waitting around an doing it at 100k, thats horse**** anyway!!! 100k on a set of plugs, yea your really getting the best preformance out of them as if you would if you changed them at say 50k. Just something to think about and the amount of FUEL your blowing away and the price just shot back up to like $2.40 for 87 Oct.
Well guys I wanted to make sure that the 06's were safe and they are not. I have 32000 on my 06 and I pulled the plugs they break loose with about a half a turn and then get very hard to turn. I managed to get all mine out without breaking and put antisieze on them and reinstalled. All of the plugs had rust on the heat shields and thats what made them hard to come out I am confident in them now.
I'm confused about a few steps in the process.
1.Why would you put anti-seize on the electrode instead of the threads?
2.Why would the engine "hydro-lock" from some PB blast in the cylinder?
I've done my share of mechanical work but depending on what the dealer charges to change a set of plugs, I might just have them do it and save me the hassle. My 05 is 18 months old and has 33,000 miles on it.
1. The threads are not galling and causing the breakage. The breakage comes from the shank below the threads seizing in the head, which is why the anti-seize is applied to it. Do not put it on the arcing area of the electrode.
2. It probably won't lock from "some", but it also probably doesn't take very much to fill the combustion chamber enough to make a real ugly mess of the engine. Liquids and combustion chambers do not play well together.
