Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-28-2007, 01:24 PM
Zen Punk is starting off with a positive reputation.
Swapping A4LD from 4.0 93 AWD to 3.0 89 RWD - things to look out for?
The transmission in my 3.0 RWD 89 is giving out - no reverse, shifts late, drives forward in neutral. The van's not worth enough to get a pro tranny job, so I'm going to have a friend swap out a tranny for me. I've come across a 93 for cheap, so I may buy it for it's transmission. It's a 4.0 with AWD, will this present any problems when I go to swap the transmission?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-01-2007, 04:19 AM
xlt4wd90 is starting off with a positive reputation.
Zen,
The AWD transmission has a different tail shaft and housing that the transfer case bolts to. The drive shaft may be different lengths as well.
You might consider going with the 93 AWD, as it's got much more going for it. Move as much usable parts from your 89 to the 93 as you can.
  #3 (permalink)
Old 03-01-2007, 04:59 AM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
can transfer the rear housing and tail shaft off the 89 to the 93 tranny.
but I believe there are differences in the way the torque converter lockup is implemented in early vs later A4's...from memory only...may be tranny wiring harness issues and ECU issues
info on these are getting long in the tooth, I don't have Service info or tranny manuals on early A4's
the 93 A4 4L tranny is a much more rugged stronger tranny with lots of improvements to bushings, bearings, valve body, clutch packs drums and bands
  #4 (permalink)
Old 03-01-2007, 12:21 PM
copper_90680's Avatar
copper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to behold
Hi Zen:
Welcome to our FTE forum
__________________
Tung
'93 3.0L Aerostar 2WD
'95 4.0L Aerostar AWD
'93 3.8L Taurus
Please check out our guideline
http://www.ford-trucks.com/guidelines.html
Wife? What wife? Oh, The Supreme Commander!
  #5 (permalink)
Old 03-02-2007, 12:18 AM
JTHill24 is starting off with a positive reputation.
Plus the 89 is a floor shift and the 93 is a Coluum shift.
If you look on the trans where the shift cable hooks up it will be differant. The Shift arm hangs down on one and sticks up on the other.
I think one pulls to change gears and the other one pushes.
JaY
__________________
Removing from the Front a Aerostar 3.0/4.0 Engine & Rebuilding a 3.0 WebPage
(New Home)
http://www.webng.com/JTHill/
  #6 (permalink)
Old 03-02-2007, 12:06 PM
sicdefused is starting off with a positive reputation.
(((i am no expert on this))) but i belive i would pull and (((-LABEL-))) all the wiring harnesses sencers and computer at the same time along with the 4.0 leaving as much of the wireing intact as possable..... then i belive the transaction will go vary smooth........ JMO
GOOD LUCK and keep us updated
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
