Hard starting when cold - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 09-11-2002, 09:29 PM
bronco cam bronco cam is offline
bronco cam is starting off with a positive reputation.
Does anyone know if there is a switch or sensor that acts as a choke on a 96 ford 351? My bronco is hard to start when cold, starts okay after warmed up. Could this problem be the fuel pump not putting out enough pressure when starting?
Old 09-12-2002, 03:37 PM
JBronco's Avatar
JBronco JBronco is offline
JBronco is starting off with a positive reputation.
What do you mean by "hard starting?" Hard to crank, cranks too long, stalls, runs rough, etc.? A bad EGR will cause hard cold starting and rough running until it warms up.
Old 09-12-2002, 03:50 PM
yosemite yosemite is offline
yosemite is starting off with a positive reputation.
Mine cranks too long and then runs rough, surging some, and stalls sometimes especially when put into gear. It runs rough at idle though(surging) all the time and I haven't pinpointed the problem yet.
Changed EGR valve, EVP sensor, PCV valve, spark plugs, wires, air filter, fuel filter and i think thats it.
Brian
1988 Eddie Bauer 351
Old 09-12-2002, 04:01 PM
That is the sympton exactly it seems to crank to long then it will fire and die. Then on the second try it will start but seems to run cold (like it has a carb with out a choke) but once it is warmed up it runs fine.
96 Ford Bronco 351
Old 09-12-2002, 10:06 PM
JBronco's Avatar
My mistake...a bad EGR valve does not cause those symptoms, I was thinking of something else (bad choke pull-off on a carb). But something may be causing your truck to run rich upon startup, wetting the plugs and causing it to run bad until it gets warm enough to dry the plugs. That is what a bad choke pull-off will do, although you do not have a choke, the symptoms are the same.
Old 09-15-2002, 04:48 PM
bronco351 bronco351 is offline
bronco351 is starting off with a positive reputation.
My bronco used to do the same thing. I had a 650 cranking amp battery in it. I replaced the battery with a 950 cranking amp battery and it started much easier!!
Old 09-15-2002, 10:21 PM
etherdan etherdan is offline
etherdan is starting off with a positive reputation.
I am having the exact same problem. After starting it wants to idle at 400 to 500 RPMs instead of the usual 900 to 1200 when cold. After warming up it is fine. A plug, distributor cap, and plug wire change did not help. Seems electronic to me. Help us out one of you tech wrenches.
Old 09-15-2002, 11:51 PM
[updated:LAST EDITED ON 15-Sep-02 AT 11:53 PM (EST)]I also changed plugs, wires, cap, rotor and I put in a new coil. Still have the same problem. I hope someone has a idea.It seems like i am not getting enough fuel pressure at start up but it does sometimes smell like it is running rich. Any help please.
Thanks
Old 09-16-2002, 09:54 AM
sideout2 sideout2 is offline
sideout2 is starting off with a positive reputation.
Check or clean out the air bypass valve. This is the "choke" of the fuel injection.
Old 09-16-2002, 12:23 PM
I posted earlier that mine is doing the same thing. Idles at 600 when idling, especially when cold and surges. Is 900-1000 the norm?
I'm going to check my Idle Air Bypass Valve.
Brian
1988 Eddie Bauer 351W
Old 09-16-2002, 02:59 PM
Pioneer Ford Pioneer Ford is offline
Pioneer Ford is starting off with a positive reputation.
Cold Start 66shadow 1999 - 2003 7.3L Power Stroke Diesel 4 10-14-2012 11:02 PM
95 Bronco 351W hard cold starting. Help! coolcat3406 1978 - 1996 Big Bronco 3 09-29-2004 12:22 PM
89 Bonco hard cold starts drgracdad 1978 - 1996 Big Bronco 2 01-13-2004 12:10 PM
Villager van hard to start when cold. keith w 1987 - 1996 F150 & Larger F-Series Trucks 5 09-04-2003 12:36 PM
hard starting bronco bronco cam 1978 - 1996 Big Bronco 1 09-07-2002 12:50 AM
Tags
351w, bronco, cold, ford, hard, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford is a registered trademark of the Ford Motor Company.
