compression of a 393 with flat top pistons?
on
It's AMAZING what you can find on the web these days.....
http://www.rbracing-rsr.com/compstaticcalc.html
your cam will have a big effect on how much compression you can run.
it's all about the combo
you don't want to run a cam with 244*@ .050 with 8 to 1 compression it will be a dog big time until it start building cylinder pressure.
same goes with a 10 to 1 compression motor, with a 208* @ .050 it will ping like a bitch.
it all has to match to work right......
I've seen guys that want that big cam sound so they buy a cam that gives it to them but they do nothing about the compression. they bitch because it's a dog off the line and don't make any power until 3000.
most cams will come with recomended compression ratios.
figure out where you want it to run...pick a cam that will get it there ...and then build your compression to match the cam.
give Cam Research a call all he does is FORDS
Scroll down on this ebay add and there's a table listing cr's for different stroker/piston/head combos. A 393 w/ flat tops and 69cc chambers shows ~ 10:1
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
[QUOTE=BaronVonAutomatc]Scroll down on this ebay add and there's a table listing cr's for different stroker/piston/head combos. A 393 w/ flat tops and 69cc chambers shows ~ 10:1
http://cgi.ebay.com/ebaymotors/FORD-427-393-408-FORGED-STROKER-5-0-351W-MUSTANG-TMD_W0QQcmdZViewItemQQcategoryZ33620QQihZ008QQitem Z180090850816QQrdZ1QQsspagenameZWDVW[/QUOTE]
Now stick the pistons .009 out of the block and see what you have. I bet it's up there....
Ok I ran it on Desk Top Dyno to get the compression for you.
69cc head
.041 gasket
-.009 deck (piston sticking out of the block)
4.030 bore
3.850 stroke
flat top piston no reliefs 11.63
-10cc dish......10.39
-15cc dish......9.88
-20cc dish......9.41
-25cc dish......8.99
hope this helps.........
69cc head
.041 gasket
4.030 bore
3.850 stroke
76250_4x4
01-03-2012 03:39 PM
Justins68ford
07-23-2011 06:36 PM
1972 Ford Thunderbird 429 V8
12-19-2008 05:42 PM
bigred
02-14-2001 04:47 PM
