Oil Filter Wrench Size??
Old 02-27-2007, 07:18 PM
FOSE88's Avatar
FOSE88
FOSE88 is offline
OK, Call me lazy. I know I've seen it somewhere in this forum. Getting close to the first oil change in my 07, E350, 6.0. What size socket is needed to remove the oil filter? Was it 27mm?
Old 02-27-2007, 07:25 PM
origcharger's Avatar
origcharger
origcharger is offline
I believe its 36mm. Do yourselve a favor and check in the "Lisle" tool rack for their slick 3/8" drive 6.0 oil filter socket.
Oops you said E-350, that van may use a differant size.
Old 02-27-2007, 07:26 PM
LAWNMOWER MAN's Avatar
LAWNMOWER MAN
LAWNMOWER MAN is offline
I Believe It Is 36 Mm For The Oil Filter Cap
Old 02-27-2007, 07:27 PM
cudajim's Avatar
cudajim
cudajim is offline
1 7/16 is what I use, just looked in the tool box
Old 02-27-2007, 07:28 PM
Green_Monster's Avatar
Green_Monster
Green_Monster is offline
Smile oil filter socket
There is a seller on ebay that sells a mac tools socket that is a combo for both the fuel and oil filters I thinks it is like 36 & 35 mm it is a combo socket and sells for like 15 bucks delivered or you could just use the right size wrench. Just be careful to not overtighten it as YOU WILL CRACK THE PLASTIC CAP and do change the O-ring DO NOT reuse the old one.
There is a section on this in the 6.0 tech folder as well on how to do alot of things to this motor: here is the link for the oil filter
http://home.austin.rr.com/sbv1/Proce...gEngineOil.htm
Old 02-28-2007, 07:10 AM
origcharger
On our E450, the filter housing always comes loose when I use the metric allen wrench to remove the drain plug in the center of the hex, I then just hold it with my hand and remove the drain plug. After the filter drains I spin the housing off with my hand, I have never actually used a socket on it.
Old 02-28-2007, 02:14 PM
Jim Haynes's Avatar
Jim Haynes
Jim Haynes is offline
I bought my oil filter wrench for my 2004 PSD from my Ford dealer. It is 36mm. Jim Haynes
72CC428
05-02-2016 08:05 PM
whiskey runner
02-10-2016 02:52 PM
wahfulls
Modular V10 (6.8l)
15
11-12-2015 06:12 PM
wahfulls
Modular V10 (6.8l)
01-12-2013 11:49 PM
chandlerbf
07-31-2004 11:30 AM
Quick Reply: Oil Filter Wrench Size??
