best 4x4 '73~'79
Old 02-27-2007, 06:01 PM
plow/truck's Avatar
plow/truck
plow/truck is offline
best 4x4 '73~'79
A while back, I asked about adding power steering to a 73 f350. It seems pretty involved and now considering going a different route. I’m thinking of getting a newer truck and
building it for our snow plow.
<o> </o>
Here are some questions:
Are the ’73-‘79 front end (frame area) the same on 3/4 tons? We want to be able to convert the plow just by bolting it on.
Do they make a 3/4 ton 4x4 short bed?
Is there a year that is better or worse than others?
Please confirm my thought that a 2wd power-steering won’t work on a 4x4.
Thanks, for the help.
P/T
Old 02-28-2007, 11:12 AM
bigperm2's Avatar
bigperm2
bigperm2 is offline
1. My gut says "no", I think the hiboy/lowboy frames are different. Someone on the list should be able to verify.
2. No 3/4 ton short beds.
3. That is up to opinion. The highboys had factory divorced t-cases, power assist steering, and a narrower frame, but the highboys are taller.
4. you are correct that 2wd power-steering won't work on a 4x4, since most 2wds are rear steer, and the 4wds are front steer, the pitman arm turns opposite directions.
Old 02-28-2007, 03:05 PM
scottie2hottie's Avatar
scottie2hottie
scottie2hottie is offline
I used to plow for guy he had both a 77 highboy and a 78. the 78 was the truck i preferred for plowing, but thats mostly because it was auto the other was stick. they do no make a reg cab short bed 4x4 3/4 ton. 2wd steering is behind the k member while the 4x4 is in front of the frame: not compatible. earlier models will keep you out of smog and you'll feel more power.
Old 02-28-2007, 03:25 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
Opinions will differ from what year may be the best. "If it's a FORD, it's all good". IMO, I would say the 78/79 models F250s were better because of the upgraded power steering from the Power Assist. Asside from 77.5, the Front ends were open knucked. Also, if it matters, the In Cab fuel tank moved back to the rear, so you could change the 19 gal out to a 38 gal if you wanted.
But, no year is really that superior to the next. Just depends on what you like the best.
Old 02-28-2007, 03:30 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Find a 79 F350 4x4 and stuff a 460 in it.
Old 02-28-2007, 08:52 PM
unrulee's Avatar
unrulee
unrulee is offline
What he said minus the 460 (I'll stay with the 400 thank you ).
Old 03-01-2007, 05:25 AM
scottie2hottie
stay newer than 75 for disc brakes
unrulee- i got a D60 out of a 90 F350, you interested? It is high pinion, king pin. I would also knock a little off the cost if you threw in your D44 front
Old 03-03-2007, 05:23 AM
78f3504x4's Avatar
78f3504x4
78f3504x4 is offline
yup, or a 77.5-79 F250 Snofighter with a Cummins swapped in
Old 03-03-2007, 06:33 AM
voltson's Avatar
voltson
voltson is offline
Was this a factory package or special model? If so, what made it unique?
Old 03-03-2007, 06:42 AM
Thomasm67's Avatar
Thomasm67
Thomasm67 is offline
One of the OffRoad Mags picked the 79 f350 as the best F series of 73-79 due to the fact it had a D60 upfront and i'm sure other reasons had effects on there decision.
Old 03-03-2007, 12:54 PM
Matts72's Avatar
Matts72
Matts72 is offline
Among other things, it had cab running lights, dual batteries, dual tanks, and a Dana 60 front axle.
Old 03-03-2007, 01:54 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
The 78/79 were the best for the reasons listed.
Quick question: I'm looking at a '76 F250 4x4. Is it supposed to have disc brakes from factory?
Old 03-03-2007, 01:55 PM
Thomasm67's Avatar
Thomasm67
Yes i have a 76 Hiboy and it has Disk brakes
Old 03-03-2007, 02:03 PM
Jermafenser
Thanks, Thomas.
Old 03-03-2007, 02:14 PM
unrulee's Avatar
unrulee
unrulee is offline
That was 4wheel and Offroad, they also said that it came with a 460, and I think they said it had a 70 rear.
Quick Reply: best 4x4 '73~'79
