best 4x4 '73~'79 - Ford Truck Enthusiasts Forums
best 4x4 '73~'79
Old 02-27-2007, 07:01 PM
plow/truck's Avatar
plow/truck plow/truck is offline
plow/truck is starting off with a positive reputation.
best 4x4 '73~'79
A while back, I asked about adding power steering to a 73 f350. It seems pretty involved and now considering going a different route. Iím thinking of getting a newer truck and
building it for our snow plow.
<o> </o>
Here are some questions:
Are the í73-Ď79 front end (frame area) the same on 3/4 tons? We want to be able to convert the plow just by bolting it on.
Do they make a 3/4 ton 4x4 short bed?
Is there a year that is better or worse than others?
Please confirm my thought that a 2wd power-steering wonít work on a 4x4.
Thanks, for the help.
P/T
Old 02-28-2007, 12:12 PM
bigperm2 bigperm2 is offline
bigperm2 is starting off with a positive reputation.
1. My gut says "no", I think the hiboy/lowboy frames are different. Someone on the list should be able to verify.
2. No 3/4 ton short beds.
3. That is up to opinion. The highboys had factory divorced t-cases, power assist steering, and a narrower frame, but the highboys are taller.
4. you are correct that 2wd power-steering won't work on a 4x4, since most 2wds are rear steer, and the 4wds are front steer, the pitman arm turns opposite directions.
Old 02-28-2007, 04:05 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
I used to plow for guy he had both a 77 highboy and a 78. the 78 was the truck i preferred for plowing, but thats mostly because it was auto the other was stick. they do no make a reg cab short bed 4x4 3/4 ton. 2wd steering is behind the k member while the 4x4 is in front of the frame: not compatible. earlier models will keep you out of smog and you'll feel more power.
Old 02-28-2007, 04:25 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Opinions will differ from what year may be the best. "If it's a FORD, it's all good". IMO, I would say the 78/79 models F250s were better because of the upgraded power steering from the Power Assist. Asside from 77.5, the Front ends were open knucked. Also, if it matters, the In Cab fuel tank moved back to the rear, so you could change the 19 gal out to a 38 gal if you wanted.
But, no year is really that superior to the next. Just depends on what you like the best.
Old 02-28-2007, 04:30 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Find a 79 F350 4x4 and stuff a 460 in it.
Old 02-28-2007, 09:52 PM
unrulee's Avatar
unrulee unrulee is offline
unrulee is gaining momentum as a positive member of FTE.unrulee is gaining momentum as a positive member of FTE.
What he said minus the 460 (I'll stay with the 400 thank you ).
Old 03-01-2007, 06:25 AM
stay newer than 75 for disc brakes
unrulee- i got a D60 out of a 90 F350, you interested? It is high pinion, king pin. I would also knock a little off the cost if you threw in your D44 front
Old 03-03-2007, 06:23 AM
78f3504x4's Avatar
78f3504x4 78f3504x4 is offline
78f3504x4 is starting off with a positive reputation.
Quote:
yup, or a 77.5-79 F250 Snofighter with a Cummins swapped in
Old 03-03-2007, 07:33 AM
voltson's Avatar
voltson voltson is offline
voltson is starting off with a positive reputation.
Quote:
Was this a factory package or special model? If so, what made it unique?
Old 03-03-2007, 07:42 AM
Thomasm67's Avatar
Thomasm67 Thomasm67 is offline
Thomasm67 is gaining momentum as a positive member of FTE.
One of the OffRoad Mags picked the 79 f350 as the best F series of 73-79 due to the fact it had a D60 upfront and i'm sure other reasons had effects on there decision.
Old 03-03-2007, 01:54 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Quote:
Among other things, it had cab running lights, dual batteries, dual tanks, and a Dana 60 front axle.
Old 03-03-2007, 02:54 PM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
The 78/79 were the best for the reasons listed.
Quick question: I'm looking at a '76 F250 4x4. Is it supposed to have disc brakes from factory?
Old 03-03-2007, 02:55 PM
Thomasm67's Avatar
Yes i have a 76 Hiboy and it has Disk brakes
Old 03-03-2007, 03:03 PM
Thanks, Thomas.
Old 03-03-2007, 03:14 PM
unrulee's Avatar
Quote:
That was 4wheel and Offroad, they also said that it came with a 460, and I think they said it had a 70 rear.
THIS is what ill be driving 351Cleveland C4 The Next Generation 23 09-23-2013 07:00 PM
snow plow late70sfordnut 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-01-2008 07:32 PM
Bronco snowplow? plow/truck 1978 - 1996 Big Bronco 9 02-06-2007 08:43 AM
Please help ID my rear axle tietje_3 1999 to 2016 Super Duty 3 09-28-2006 09:31 AM
oil weight, same as T case? plow/truck 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-23-2006 06:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
