Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-27-2007, 04:14 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
Exclamation 4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK HERE
I am making a sticky for the numerous people with transmission problems. If you own a ranger or explorer you might be experiencing numerous shifting problems. If you would feel free to post here so we can have a running record of problems and multiple people who can assure that we have a correct fix.
I also have a tutorial available for the infamous " valve body " gasket. click the following link
http://www.ford-trucks.com/article/i...dy_Gasket.html
Thanks
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #2 (permalink)
Old 02-27-2007, 05:44 PM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
Gonna be a daddy!!!
2002 Ford Ranger
bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of
I have the 5R55E in my 02. Had shifting problems taken care of while still under warranty. There's still a hard shift from first to second, after a hard launch, usually trying to make the advanced green turning light. The next 3 or 4 stop lights will have a hard shift into second after that, somewhat like a cooling off period. Can't figure it out.
Anyway, someone posted about a shift kit that would help my symptoms. Haven't looked into it yet, but still in the back of my mind.
__________________
Joe, who's GONNA BE A DADDY!!! drives an 02 supercab shortbed 3.0 liter automatic power nothing Ranger Edge.
BC Chapter Member
VOTE IN ROUND 10!!!
  #3 (permalink)
Old 02-27-2007, 06:50 PM
CMOS CMOS is offline
CMOS is starting off with a positive reputation.
I bought my 04 with the 5R55E about 3 weeks ago (31K miles). During the test drive I did notice hard shifts both up and down from 1-2-3 and 3-2-1. Also noted that when shifting from D to R it took about 4 full seconds for the shift to take place.
Took it to the local Ford Dealer and they did an overhaul. Drives great now. Parts repalced were:
F77Z*7153*AA, Kit, Gasket (1)
XL2Z*7A098*CA, Screen Assy (1)
4L5Z*7D034*AA, Band Assy (1)
4L5Z*7A100*BA, Control Assembly (1)
1L5Z*7B164*BA, Plate Assy, Drive (4)
F77Z*7B442*AA, Driven Plate, Steel (4)
Diag statement on the dealer receipt says the above problems I described was caused by "burned bands and clutches".
CMOS
PS: Here's a link to a shift kit for the 5R55E - Click HERE
__________________
2001 Sport-Trac, 2WD, 4.0, 5R55E Auto, 4.10 gearing
"Faith in Government defies both history and reason."
  #4 (permalink)
Old 03-03-2007, 03:39 PM
econolinedriver econolinedriver is offline
econolinedriver is starting off with a positive reputation.
Cool 2001 Ranger tranny problem
My 2001 2WD Ranger (3.0 engine, auto tranny) is having problems. When it makes its initial upshift from first to second, it shifts hard and at a high RPM. The overdrive light starts to blink. Whats wrong and how much will this cost??
  #5 (permalink)
Old 03-03-2007, 04:00 PM
fordboy_52's Avatar
i sent you a pm, it sounds like the valve body gasket problem. i can tell you that mine was under $100 to fix. which was awesome when ford wanted to put a tranny in for $4000
Matt
__________________
  #6 (permalink)
Old 03-04-2007, 05:12 PM
bradman755 bradman755 is offline
bradman755 is starting off with a positive reputation.
flashing od explorer
I have 133000 and my Explorer od light starts flashing then the trans goes into limp mode I am going to try the valve body soleniod and new fluid I'll let you know
  #7 (permalink)
Old 03-04-2007, 05:18 PM
fordboy_52's Avatar
while your replacing the selenoid you should replace the gasket.... it wont cost much more
Matt
__________________
  #8 (permalink)
Old 03-04-2007, 09:44 PM
ranger racer ranger racer is offline
ranger racer is starting off with a positive reputation.
My 05 ranger 3.0 2wd with a 5r55 was slipping when shifted into drive. It took me over 10 trips between 3 different dealerships before they did an overhaul. The thing that kills me is all the dealerships saw it slipping but it didn't throw any codes so they won't do any thing until I decided to be an ********* to them
  #9 (permalink)
Old 03-04-2007, 09:58 PM
fordboy_52's Avatar
well the 05 doesnt have the known valve body issue... im not sure what it could be
__________________
  #10 (permalink)
Old 03-05-2007, 09:55 PM
captchas's Avatar
captchas captchas is offline
captchas has a very good reputation on FTE. captchas has a very good reputation on FTE. captchas has a very good reputation on FTE.
if anyone has this problem we can supply you with all the parts needed to this repair or help you out with a exchange rebuilt valve body,
as to filing these units when there is no fill plug the oil must be pumped into the trans though that small drain/fill plug untill it jt runs out lightly when running and fully warmed up to operating temps. or we can furnish you with a deeper alloy pan that has a dipstick adapter built into the kit
we are a fte sponsor and can be contacted through
www.level10power.net
  #11 (permalink)
Old 03-06-2007, 04:44 PM
fordboy_52's Avatar
guys, my repair manual is now online!!
Matt
__________________
  #12 (permalink)
Old 03-06-2007, 05:52 PM
Matt
Excellent.
What part of this job takes the most time? Meaning, why the 5 hours?
Thanks,
CMOS
__________________
  #13 (permalink)
Old 03-06-2007, 07:58 PM
fordboy_52's Avatar
dropping the pan and pulling the valve body, than reinstall
__________________
  #14 (permalink)
Old 03-06-2007, 09:36 PM
Does the 2004 5R55E have this issue?
I ask because FORD recently rebuilt my tranny (see above post) but I don't know if they used any "upgraded" parts, if applicable.
Thanks for any info.
CMOS
__________________
  #15 (permalink)
Old 03-06-2007, 09:55 PM
fordboy_52's Avatar
as far as i know, the answer is no.... they have a selenoid stick as far as i know
Matt
__________________
Tags
5r55 , 5r55e , 97 , bands , ford , mazda , problems , ranger , replacement , reverse , shift , solenoid , tightening , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
