Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #121 (permalink)
Old 04-20-2007, 09:39 AM
gearheadz80 gearheadz80 is offline
gearheadz80 is starting off with a positive reputation.
I have a '97 and a '02 4x4 ranger, both 5 speed auto. The '97 just rebuilt by a former ford tech that went out on his own. He said the bonded gasket is now superceeded and is now updated to a thicker plate instead, He found a bonded plate but they are getting hard to come by now. Anyone else hear of this?
Well the '97 was really messed up, wouldn't work after rebuild. I Let him pull the valve body out of the '02, and we made progress but it still wasn't right. Pulled body again and looked at the gasket (bonded) and saw that one of the passage ways on the case was warped because it showed up on the gasket. Case was warped. So since the '02 is smashed up at the moment he swaped cases with each other. Gives him a chance to go throgh and check out both trans!!! I'm okay with that!!!
__________________
If its not broke Drive it till it is.....
  #122 (permalink)
Old 04-20-2007, 11:04 AM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
yea, im not sure but id bet that my plate was thicker too.
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #123 (permalink)
Old 04-21-2007, 09:33 AM
MRStace84's Avatar
MRStace84 MRStace84 is offline
MRStace84 is starting off with a positive reputation.
I saw this post, maybe someone here can help me out.
I've got a 2003 Ford Explorer. Automatic Transmission. The O/D light is flashing, and the Service Engine Light came on with a code P0775 Pressure Control Solenoid B Malfunction. The symptons while driving is the car revs up a little bit to much while shifting gears.
I have seen the posting regarding the leaking seperator plate gasket, but the TSB only goes up to 2002, so I am thinking this may not be the problem, but instead a bad solenoid.
Any suggestions?
Thanks!
  #124 (permalink)
Old 04-22-2007, 12:31 AM
homie homie is offline
homie is starting off with a positive reputation.
I have a 97 explorer 4x4 I'm having a slipping in reverse would that be the shift kit problem also
  #125 (permalink)
Old 04-28-2007, 11:58 PM
RXFreddie RXFreddie is offline
RXFreddie is starting off with a positive reputation.
No Reverse
After reading for hours I decided to ask! I shifted into reverse today, and once I was already moving, gave it a little gas, not alot, but anyway it made a lound bang and I thought the drive shaft hit the ground. After that when you hit reverse you can here and feel it try to back-up then acts just like it's in neutral.Can someone tell me what may be the problem. Maybe time for a rebiuld? 192560 miles on it and no major problems til now. Thanks for any and all help. It was serviced about 4mths ago. It has been working fine with no noises or slipping. It just happened all of a sudden. 97 xlt ext cab 4.0 AOD 192560 miles.
  #126 (permalink)
Old 04-29-2007, 12:10 AM
fordboy_52's Avatar
i dont think its worth putting any money into a 192k tranny. i would just have it rebuilt.
Matt
p.s. u were pretty lucky to get that out of it
__________________
  #127 (permalink)
Old 04-29-2007, 12:20 AM
I figured it would need a rebiuld, but I was just wondering what may have broken in it? You know just curious. Oh yeah do you have a guesstimate on what the cost might be? Thanks.
  #128 (permalink)
Old 04-29-2007, 12:24 AM
fordboy_52's Avatar
i expect that the clutches are worn out. any other gears with problems?
Matt
__________________
  #129 (permalink)
Old 04-29-2007, 12:31 AM
no other problems. as I said it was a really loud bang and then it as if you put it in neutral. all forward gears are fine.
  #130 (permalink)
Old 04-29-2007, 12:45 AM
fordboy_52's Avatar
as for the price, its alot and thats all i know. i wouldnt suggest a salvage tranny because of all of the problems that exsist.
Matt
__________________
  #131 (permalink)
Old 05-02-2007, 10:10 AM
Quote:
a little more info my explorer is a 4.0 sohc control trac with 130000 miles the slipping at first was random and only after driving several miles but is happening more often now i did the manual first engine braking and it seemd as if it was in neutral so could this be the seperator plate and or the shift kit problem
thanks for help homie
  #132 (permalink)
Old 05-02-2007, 07:21 PM
V-10 runner V-10 runner is offline
V-10 runner is starting off with a positive reputation.
I have a 2001 ranger 4x4 auto, my trans seems to take a moment to go
into reverse, then a clunk. The forward gears seem fine. Had the trans
flushed, still seem to have this problem. Any idea's
Thanks.
  #133 (permalink)
Old 05-02-2007, 09:57 PM
fordboy_52's Avatar
if you have no manual first it does sound like a seperator plate issue. as for the clunk, im clueless
Matt
__________________
  #134 (permalink)
Old 05-03-2007, 06:28 PM
fflintstone's Avatar
fflintstone fflintstone is offline
fflintstone is starting off with a positive reputation.
Thanks.
That clunk going into reverse has always been such a common problem on rear drive vehicles that mechanics took to telling everybody 'they all do it, it may be annoying but don't wory about it'. My old Dodge did it, so did my GMC. My old 87 F150 didn't, but it was a manual. Sometimes its U joints, or I've thought it was a sloppy differential but after having it checked for excessive backlash, everything was in spec. As I've been getting older and wiser, I'm beginning to think that it's related to that same clunk that you get when comming to a stop and easing up on the brake. That problem has been confirmed to be the tranny yoke getting dirty and sticking. There is normal movement in and out there as the drivetrain and suspension are working. The cure is to remove the driveshaft and clean/lube the yoke and spline. If you get a chance V10-runner, try that. I'd be anxious to hear what you find. There are a couple of threads on the clunk at stop lights.
Fred
__________________
Freddy Flintstone
2007 FX4 Off-Road, 4.0L SOHC, 8.8" 4.10 L/S, 5 spd M5OD, Tilt/Cruise, Crank windows, Manual locks, NO jumpseats, NO rear slider. An no rear stabilizer .
" A stone is not a Rock" - Ruskin.
"Life is what it is. No more, no less" - fflintstone.
  #135 (permalink)
Old 05-04-2007, 08:47 AM
Thanks Fred i'll try that. Other than the reverse slip, the trans
feels fine.
Tags
5r55 , 5r55e , 97 , bands , ford , mazda , problems , ranger , replacement , reverse , shift , solenoid , tightening , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
