Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Transmission Guides
- Why is My Transmission Slipping?
Guide to diagnose trouble and recommended solutions
4r55e 5r55e Ranger / Explorer Transmission Problems - CLICK HERE
#856
OK, the valve body swap did not fix my reverse issue. So, it looks like a rebuilt is in in my plans.
I'm going to follow some local leads this week. Also exploring any transmission rebuilders that sell online and ship and do decent quality work. found a place in IL, Shift Rite Transmisssions, anyone heard any good or bad about them?
TIA
TIA
#857
Well I never did pull codes, I assumed (yeah I know) if the "OD off" light isn't flashing there is no code. But I can check tomorrow.
The symptoms are: when cold reverse does not engage at all. If I put it in L1 or L2 and stand on the brake while revving the engine for a bit I can finally get reverse to engage but it's pretty hard. Similar if I drive around the block and shift to reverse there will be a delay before it slams into reverse. Not an expert but it sounds like a pressure problem to me.
I'll try to get codes.
Thanks
Thanks
#858
If the foward gears are ok, the pump pressure is likely ok, so given your description, I'd maybe suspect a control problem, like a shift solenoid. So if the battery hasn't been disconnected since it last acted out with a lit OD light, there should be a code/s clues in the tranny controller/computer, but you'll need a scantool that can access that controller, like the ELM mentioned above, or a high end tranny shop or gararge scantool to extract the codes. Let us know what you find.
EDIT: What kind of shape was the tranny fluid in when you dropped the pan to do the valve body & what did the pan deposits look like????
#859
So far, it drives just fine going forward, manually shifting to L2 and L1 give me engine braking as always. Just seems to be getting reverse to engage that is giving me the problems. Since the rebuilt valve body included all new solenoids and shows the same symptoms as the old valve body I'm not suspecting solenoid at this time. Although I won't rule out a wiring or connector problem, or a controller module problem.
Prior to swapping the valve body I replaced the reverse servo and seals, the fluid was red. When compared to new fluid the old fluid was slightly darker. Inside of pan was clean, hardly and deposits at all. I saw a small amount of dark sludge come off the magnet when I hosed it off with brake cleaner. Even cut open the filter, again some fine sediment/sludge but no bits of gasket, seals, or anything.
#860
#861
I had a bit of time to check a few things, before heading over to the in-laws for the cookout.
I hooked up my autotap, no codes present but I'm not 100% sure it will read transmission codes. There is a transmission shop on my way home from work, if I get a chance to stop and check codes I'm also interested to see what they have to say about the operation.
I also checked tightness of the cable bracket under the steering column, went through the shift cable adjustment procedure. Also pulled off and reconnected the TRS wiring connector and the wiring connector on the side going to solenoid valves. connectors looked good. Also tried again when it is cold and reverse will engage, eventually. without going for a drive and warming things up it takes about 30-45 seconds for reverse to engage. Also noted I hear a faint "buzz" sound just before it clunks into reverse.
I'm curious what you mean by "it might not be shifting the tranny into R completely", and how the TRS fits into that? I assume you have the manual valave operated by the shifter cable, and the TRS feeds back to the controller to switch the solenoids.
#862
If you have not taken the reverse Servo apart in all your endeavors you should have this is a common problem also the valve that controls it will cause the same problem shift repair kits address this valve. If you are sure it is none of this then you have a bad reverse band or the planer gear is dying.
#863
Thanks
#864
After years of fighting my problematic poorly rebuilt 5R55E, it finally half bit the big one at just 78,000 total miles. Burned out some clutches and locked the trans in forward gear. It still shifted 1-5, but reverse turned into neutral, and neutral turned into a second drive. Drove the truck like that for two months while I collected the parts for a manual transmission swap.
The manual transmission swap wasn't easy on a PATS equipped truck, but it was well worth it in the end. Total cost was probably $1300, which still beats the cost of an automatic transmission rebuild.
Goodbye 5R55E! It hasn't been fun.
#865
Code P0735 & Blinking O/D light
Seeing as how you have a blinking OD light, it indicates the tranny controller/computer has likely stored trouble codes, so have your trusted tranny shop use their scantool to pull the codes & post All code Numbers, as they can offer up good trouble shooting clues.
If you have to fork over a pile of your gold for a tranny code scan, maybe consider opting for a low cost ELM scantool & run FORScan freeware thats tweaked for Fords & Mazda, to have it scan All of the vehicle controllers for trouble codes.
Today I took the 2001 Ranger to a local transmission place. The place is not the cleanest place but they've been in business a long time. They placed the scanner on the truck & pulled code P0735-(Incorrect Fifth Gear Ratio) He stated that it said to check the solenoids & sensors & some other things. I also do believe the trans fluid is to full. For now I'm going to try replacing the transmission sensors & if that doesn't fix it. He said I could bring it in next week & he'll check the solenoids. At which time I'll have the fluid replaced along with the filter. Having just purchased this truck a month ago & it having only 69400 miles on it I bet the fluid has not ever been changed.
Any comments?
#866
1996 Ranger 3.0 Automatic Problems Continue
Hi, Truck shifted late and hard when first purchased used a couple years ago. Transmission performance has seriously deteriorated to the point where the engine light comes on and the overdrive light starts blinking. So I followed some advice here about just replacing the gaskets as advised. I took it to a trusty shop that will only do what you ask and had the pan and valve body gaskets changed along with the tranny fluid (around $360). The tech said that the tranny must have gotten really hot because he had a hard time scraping the old gaskets off. I had hoped that the work would have fixed it, but it didn't and its only getting worse. Both lights come on in about 20 minutes of normal driving and the tach begins to crawl upwards.
So.....Should I have the shop just replace the valve body and solenoids with new, or should they have to dig deeper and rejuvenate the whole case, bands, and gears? I ask because of the difference in $. would be from $600 to maybe $2500.
Thanks, Tim
Thanks, Tim
#867
#868
#869
Transmission Oil
Many folks will disagree with what I am going to say! MercronV came along somewhere around 2004 and is a very good product. None of the transmission oil change or repair shops use it as a rule. The MercronIV with a add in package is used because it is half the price problem is it doesn't measure up to MercronV. MercronV has a much higher temperature range than other's, better lube quality and as a whole and will hold up much longer. So it looks as if you use MercronV in your Ford auto transmission it will last longer.
#870
