Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 03-06-2007, 09:55 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
as far as i know, the answer is no.... they have a selenoid stick as far as i know
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #17 (permalink)
Old 03-06-2007, 10:53 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
I have added this link to the main tech sticky at the top of the forum for all to find.
__________________
Rob
Dying's not so bad
It's living that will kill you off
  #18 (permalink)
Old 03-07-2007, 07:55 AM
captchas's Avatar
captchas captchas is offline
captchas has a very good reputation on FTE. captchas has a very good reputation on FTE. captchas has a very good reputation on FTE.
Quote:
Originally Posted by CMOS
Does the 2004 5R55E have this issue?
I ask because FORD recently rebuilt my tranny (see above post) but I don't know if they used any "upgraded" parts, if applicable.
Thanks for any info.
CMOS
from what we see comeing into the shop.yes the 5r55e dose have the gasket problem while the s and w do not suffer from this. they suffer from poped and broken snap rings on the clutch packs when line pressure is turned up to high for very firm shifts.
as ford boy states we do also see the solinode stick from which it is still easier to do with the v.b off the vehicle and on a bench at the same time doing a full upgrade/rebuild of the valve body
  #19 (permalink)
Old 03-07-2007, 08:48 AM
CMOS CMOS is offline
CMOS is starting off with a positive reputation.
cap,
Is there a way I can tell, based on what parts were replaced, if the upgrade was done?
CMOS
__________________
2001 Sport-Trac, 2WD, 4.0, 5R55E Auto, 4.10 gearing
"Faith in Government defies both history and reason."
  #20 (permalink)
Old 03-07-2007, 09:46 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
cap,
CMOS
A competent rebuild will normally include important upgrades and improved parts as a matter of course. Odds are your tranny has the upgrade(s).
P.S. Matt, nice job on the tech article.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #21 (permalink)
Old 03-07-2007, 10:01 AM
fordboy_52's Avatar
thanks, i really want to reach as many people as possible because god knows ford wants to put a new tranny in the trucks instead of fixing the problem
Matt
__________________
  #22 (permalink)
Old 03-08-2007, 01:44 PM
linkinluver07 linkinluver07 is offline
linkinluver07 is starting off with a positive reputation.
ok i need a little happy.. sold finally sold my 86 Chebby and thinkino about purchasing a 1998 Ranger from my boss.good little truck i haven't been out to see what "exactly" is wrong with it but from what he described to me it doens't shift.now i dont know if that means not at all or at extremly high RPM's I'll let you know on that Sunday when i go to look at it. ( i need something good on gas and a daily-driver). they just towed it over there and parked and its been sitting for a year.. so you guys got any ideas any help would be nice. and like a said I will give more Information as It becomes avaliable to me!
  #23 (permalink)
Old 03-10-2007, 11:51 PM
silverbullet silverbullet is offline
silverbullet is starting off with a positive reputation.
Its a 99 mazda b3000 and it started a month ago..so i changed the tranny fluid and filter and it went away..until about 3 days ago..so i brought it in and they said that it was a speed sensor..so they replaced it and it worked fine again but tonite it started to shift hard again....it only does this when i am coming to a stop between 1st and 2nd..and sometimes when i do stop and i begin to leave it seems that it is still in 2nd..so it moves slowly but with alot of revs...then it seems to sense this problem and shifts down hard to catch up..but this happens rarely..the main problem is the hard shifting when comin to a stop..any ideas..thanks
  #24 (permalink)
Old 03-10-2007, 11:52 PM
fordboy_52's Avatar
sounds like both of you have bad valve body gaskets... look for that link i posted earlier for a tutorial how to fix it
Matt
__________________
  #25 (permalink)
Old 03-11-2007, 11:06 AM
eric5324 eric5324 is offline
eric5324 is starting off with a positive reputation.
Hey guys, my 5r55e with about 95,000 miles on it is slipping while in overdrive only at highway speeds. It shifts fine below 50 and with overdrive off. It's the worst when on highway around 65-70 but not as bad if i get the rpm's up going above 75. It will do it with overdrive off going 65 too so not just overdrive. running two quarts of lucas now. Sounds like it's not a valve body problem due to it happening at higher speeds. Just wondering what yall thought. thanks.
  #26 (permalink)
Old 03-11-2007, 01:41 PM
Rockledge's Avatar
Quote:
When is the last time the tranny has been flushed and refilled with fresh ATF?
__________________
Ford Pics
  #27 (permalink)
Old 03-11-2007, 03:08 PM
i've done it probably three times with mercon v in the last year since i've started having problems so should be all new fluid by now
  #28 (permalink)
Old 03-12-2007, 10:38 PM
gearheadz80 gearheadz80 is offline
gearheadz80 is starting off with a positive reputation.
should these updates be done before before any shift concerns arise. Or just wait until shift problems start. In other words could this be preventative maintnence andmake it last longer.
__________________
If its not broke Drive it till it is.....
  #29 (permalink)
Old 03-13-2007, 02:25 PM
Marty86 Marty86 is offline
Marty86 is starting off with a positive reputation.
I have a 99 Ranger, with 73k on it, Owner has never changed the fluid, should I go ahead and change it, and hope it won't create the problem you list here?
  #30 (permalink)
Old 03-13-2007, 02:41 PM
fordboy_52's Avatar
do you have manual first engine braking?
Matt
__________________
Tags
5r55 , 5r55e , 97 , bands , ford , mazda , problems , ranger , replacement , reverse , shift , solenoid , tightening , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
