Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #271 (permalink)
Old 07-14-2008, 10:32 PM
Pinky Demon Pinky Demon is offline
Pinky Demon is starting off with a positive reputation.
Hey guys, I need more help here so sorry for the bump.
I got the Valve Body gasket fixed, it was blown out at two parts. I got the Separator plate fixed and something that had to do with shift pressure.
I still have a delay when putting in "D" though. Any suggestions?
  #272 (permalink)
Old 08-04-2008, 09:22 PM
dendo77 dendo77 is offline
dendo77 is starting off with a positive reputation.
Help!
Ok I've been reading up on all of this and here's my situation...
I had the hard shift/slipping between 2nd and 3rd? (roughly 30mph) but other than that initial slip everything was ok. I didn't have the money then to repair ir, so I drove it minimally as possible (I was laid off so it wasn't too hard)
Today, after leaving the local dunkin donuts, my reverse practically stopped working. It was slipping but barely moving. I put it into drive and same thing as reverse. I dropped it down to 2 and it drove fine. At 40 MPH i put it back into drive and still slipping. Engine revs high but barely accelerating. I then tried taking it OUT of overdrive (turning overdrive off) and it drove fine. On the highway when I reached 70, 75 I could turn the overdrive back on and be ok.
I stopped on the way home and changed the filter and fluid, to no avail. I did notice a couple pieces of what seemed to what everone is calling the valve body gasket (kinda like roofing felt). There were no metal shavings in the pan, but there was that gray metaalic sludge on the magnet. yes I did clean all of that off when I changed the filter.
Did I kill my transmission? How do I check/replace the bands? Where are the bands located? How many bands do I need? Is it even the bands at all? I am considering buying a remanufactured and tested valve body assembly with solenoids (EBAY $39.99) and the valve body gasket. If i need to replace the bands I want to have them on hand and do it all at once.
Any info or links to other sites would be greatly appreciated.
  #273 (permalink)
Old 08-04-2008, 09:23 PM
oops, forgot some info
2000 Ford Explorer Sport 4x4 with OHV engine 147,000 miles
  #274 (permalink)
Old 08-04-2008, 11:08 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
buy the reman valve body and buy a sep plate with a bonded gasket. then you dont have to worry bout it blowing out.
but remember, every time your trans has slipped (or will slip) you are causing damage.
my tranny ended up going out a year and a half later (so i traded it that day, muwahaha)
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #275 (permalink)
Old 08-05-2008, 05:40 PM
do you know where I can get the seperator plate? I've been looking around without much luck..
  #276 (permalink)
Old 08-05-2008, 06:36 PM
is the seperator plate the same as the valve body gaskets?
  #277 (permalink)
Old 08-05-2008, 07:06 PM
fordboy_52's Avatar
no, read my article and you will see. it is in this topic. The sep plate is the plate that divides the valve body and the oil gallaries that run the pressure to the different clutches / disks
Matt
__________________
  #278 (permalink)
Old 08-16-2008, 12:11 PM
Help!!!!!!
okay I just swapped the valve body, I did have a blown upper gasket..
i put everything together, torued it all down according to the book, put in the mercon fluid, started it up and NOW in Neutral AND Reverse, the Explorer wants to drive forward!!!!
  #279 (permalink)
Old 08-16-2008, 03:38 PM
fordboy_52's Avatar
one of two things could be wrong
either the shift pin is not installed correctly (the little rod that i circled in my tutorial) or else the gasket didnt get properly aligned (not possible if you used a sep plate with a bonded gasket
Matt
__________________
  #280 (permalink)
Old 08-16-2008, 04:01 PM
shift pin
I'm gonna opt for the shift pin seeing as how the VB unit came to me with the gasket and sep plate installed and tested. Thanks
  #281 (permalink)
Old 08-16-2008, 04:15 PM
fordboy_52's Avatar
how was the gasket installed? there should have been a gasket between the valve body and the sep plate, then between the sep plate and the body of the transmission
Matt
__________________
  #282 (permalink)
Old 08-16-2008, 06:33 PM
argh!!
ok well, I checked it, and yep the pin wasn't lined up.. changed that.. fixed the "all forward" problem, but now it's the same thing as before i did the valve body swap. no reverse, can't drive unless I drop it down to 1, then use it like a manual trannie.. AND now it's running rough. The engine seems to have some sort of "vacuum leak" running sluggish especially when it's in gear..
  #283 (permalink)
Old 08-17-2008, 03:53 AM
fordboy_52's Avatar
mine was like that for a day, then it corrected itself......... NO idea why.....
unplug the batt for more than 5 hours, then drive it like u stole it...... thats what i did................. ?!?!
__________________
  #284 (permalink)
Old 08-17-2008, 08:13 AM
pawpaw pawpaw is online now
pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE.
I like the wipe the computer memory part, as it likely learned some bad things while acting out.
Do you have a CEL lit, if so pull & post ALL the trouble code numbers before pulling the B- battery cable to wipe the computers memory.
To have it relearn it's cold & warm idle speed, let the vehicle completely cool down, before restarting it.
Then without touching the throttle & with ALL electrical loads off, start it & after the idle speed drops some shift into ALL gears including R, long enough to feel them engage, ending in N or P.
Don't touch the throttle or turn anything on & let it fully warm up in N or P, then shift into ALL gears again.
Now that it's relearned it's cold & warm idle strategy, do some highway & stop & go driving & see how it goes.
Ford has a specific & rather complicated & long relearn driving cycle profile, but I've had good results just doing the cold/warm idle relearn part, then just diving it like I usually do, but then I don't drive with as much "Gusto" as Matt!!!! lol
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed autograph your work with excellence
  #285 (permalink)
Old 08-17-2008, 11:52 AM
update
Okay, I went out to the exploder this morning and it ran fine, no bogging down of the engine when it is in gear. I got the codes and there was a P0720 (Output Speed Shaft Sensor) and P0174 (Too Lean Bank 2) I replaced the upstream O2 sensor on bank 2, and had disconnected the wiring harness to clear the O@ trouble, so that may have contributed to the engine running rough. Anyways Still no reverse or low gears when in drive. I did check the fluid and it's a bit low so I'm gonna add some more. I had read that it need 120psi for reverse. So I'll keep you posted, but thanks for your help guys, I really do appreciate it.
Tags
5r55 , 5r55e , 97 , bands , ford , mazda , problems , ranger , replacement , reverse , shift , solenoid , tightening , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
