Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #226 (permalink)
Old 02-25-2008, 04:04 PM
CMOS CMOS is offline
CMOS is starting off with a positive reputation.
Question: I just bought a 2001 Sport Trac 4.0 (5R55E). Tranny seems to be working well.
Would y'all recommend I go ahead and do the TSB now to avoid problems in the future, or should I just keep driving it until I exhibit some problems?
Thoughts?
CMOS
__________________
2001 Sport-Trac, 2WD, 4.0, 5R55E Auto, 4.10 gearing
"Faith in Government defies both history and reason."
  #227 (permalink)
Old 02-25-2008, 05:36 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
i would deff stay ahead of the tranny fluid changes. and if you are confident that you have the skill, i would do the upgrades on the next tranny flush.
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #228 (permalink)
Old 02-25-2008, 06:05 PM
pawpaw pawpaw is online now
pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE.
I like the keeping up on the tranny fluid changes part!!!!
Around here the old timers say "yah don't fix what aint broke" lol
So I'd probably opt to leave the tranny alone if it's doing ok.
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed autograph your work with excellence
  #229 (permalink)
Old 02-27-2008, 08:49 PM
hotroddually's Avatar
hotroddually hotroddually is offline
1974 Ford F-350
My Garage
hotroddually is gaining momentum as a positive member of FTE. hotroddually is gaining momentum as a positive member of FTE.
i replaced the shift soleniod, valve body gasket,etc. it works great now. thanks for the info.
__________________
74 f350 4x4 dually 428scj,-HOOF BEATS ARE LOUDER THAN HEARTBEATS!
2001 ranger xlt supercab 4x4
2008 ford escape xlt
2006 harley davidson softail fxst
  #230 (permalink)
Old 03-03-2008, 12:01 PM
mikecu mikecu is offline
mikecu is starting off with a positive reputation.
I have a 2006 (47K) Limited that when the vehicle is fairly cold the transmission lunges forward when just before coming to a stop. The reason I say fairly cold is that I live in the desert and it is not really that cold here, so this typcally happens when initaly driving around. It stops after about thirty mins of driving.
The dealership says that this is typical and probably a high idle problem?
I have read plenty of horror stories about Ford trannys and have had three replaced on my 01', F250, I just hope I am not going down the same path with this one.
Can anyone shed any light on this issiue for me please?
  #231 (permalink)
Old 03-03-2008, 01:38 PM
If you think the Dealer is right about a high idle condition, maybe consider removing & cleanng the IAC.
I did this on my 99 4.0L about 2 months ago & thats checked up a down shifting/higher than normal idle problem, when coming to a stop.
__________________
(Ben Franklin)
  #232 (permalink)
Old 03-03-2008, 06:47 PM
Thanks
I thank you very much for the responce. What is the IAC?
  #233 (permalink)
Old 03-03-2008, 07:10 PM
IAC = Idle Air Control solenoid.
It's mounted on the intake air tube, between the air filter & throttle body.
The computer uses it to feed by-pass air around the throttle body & thus control idle speed.
Sometimes it gets dirty with carbon deposits & the shaft connecting to the internal valve & lets too much air into the engine, whe the throttle is closed.
Only one electrical connector & two small bolts holding it on, easy to remove & clean. I used WD-40 & a foam swab to clean mine, only because I didn't have a spray can of throttle body cleaner.
If you decide to try cleaning yours, hold the little protruding cap that contains the IAC's air filter, in the up position, so any loosened crud doesn't clog the filter, or the spray solvents don't damage it.
Cleaning doesn't always work for long, so if cleaning clears the problem, but the problem returns, replace the IAC.
__________________
(Ben Franklin)
  #234 (permalink)
Old 03-06-2008, 12:17 PM
Split Rock Split Rock is offline
Split Rock is starting off with a positive reputation.
Question '96 Explorer no 2nd gear
Ok I have a '96 explorer 4.0 with 151k miles and the tranny has lost 2nd gear/or has very little left. I have read all of the pages here as well as done the fluid and filter changes (I do all the sugessted PM work and the fluid was not burt and a normal odor) I also did the Lucis . I do have engine braking in 1st but if I shift Drive to 2nd the tranny go to netural . Have had the pan down and been to the local tranny shop they said the tranny pressure was good and the solenoids were working but for some reason 2nd was slipping or not shifting (DUH!!! AS if I couldn't tell) suggested total rebuild ($1800.00 to $3000.00) because of the age and miles. I did get the code from the truck which is (P0756 Shift Solenoid B check performance or stuck). So far I have not seen this posted as of yet. Could it be a valve body/gasket problem ? O/d will blink and the ck engine light is on because of the code, I do own a scan tool and get no other codes. I now use this truck as a station car and it goes a 1/2 mile a day as is but I would like to fix it Because it is in MINT shape (plus it needs to pass N.Y. State inspection the check engine light is a big no no but the scan tool fixed that for now ). I have 95% of all the tools I'll need. I wanted to try a rebuild on my own but after looking at the manual and pic's not so sure to date all I have ever done with transmissions is remove and replace .
If anybody has any ideas or info please post it or email me....
Also if any one has any feed back on the Phoneix Remanufactured Transmissions www.phoenixhardparts.com (thinking of just getting the tranny $599.99 + 300.00(del)+350.00(core)=$1250.00- 350.00(core return)= $900.00) this is the ebay price (Item number: 160213373704)
Thanks
  #235 (permalink)
Old 03-06-2008, 12:34 PM
fordboy_52's Avatar
yours might be too far gone to fix, id explore a new tranny option (or rebuild your current one)
Matt
__________________
  #236 (permalink)
Old 03-06-2008, 05:06 PM
Ol'Blackbetty31 Ol'Blackbetty31 is offline
Ol'Blackbetty31 is starting off with a positive reputation.
Exclamation 2000 ranger
i ahve a 2000 ranger with 2.5 and auto. When i put the new swampers on it i have bad shifting problems. when shifting from 2nd to 3rd and sometimes 1st to 2nd. it revs real high and wont shift unless i let go of the throttle. i changed tranny filter and fluid put nothing. anyone have any ideas? please!
Jarred
  #237 (permalink)
Old 03-06-2008, 11:48 PM
kel_bs sweak under dash/seat
I now have a sweaking(as if something needs to be greased) under driver's seat and under the dashboard/driveshaft or steering column/wheel????? Can't really pinpoint where in the steering it's coming from.
Kel_bs,
In the past I have found that sweaking form under the seat area which is near the back of the tranny or sweaking near rears is a dry/bad u joint
  #238 (permalink)
Old 03-07-2008, 12:03 AM
Thanks Matt, I think maybe right just wanted get some feed back. Has any body delt with Phoenix Transmission rebuilders?
  #239 (permalink)
Old 03-07-2008, 10:25 PM
wescow wescow is offline
wescow is starting off with a positive reputation.
'96XLT Tranny Problem?
My '96 Explorer XLT 4.0L (approx 140K miles) recently exprienced a drivetrain failure. It will not move in either forward or reverse. If I jack up the rear end & put it in gear, the wheels move in the appropriate direction (forward or backward). When lowered to the ground, it will move in forward or reverse VERY slowly if I rev up the engine. Other than a faint "scraping" sound coming from the bellhousing area when in gear, nothing else seems unusual---fluid level is fine & appropriate color. Also, when the vehicle moves either forward or backward (slowly) there are no unusual noises. Am I most likely looking at a TC failure or something more extensive? Any info would be greatly appreciated!
  #240 (permalink)
Old 03-11-2008, 06:24 AM
soundman502's Avatar
soundman502 soundman502 is offline
soundman502 is starting off with a positive reputation.
I've been thinking that I had the gasket problem, but now I'm not so sure. I pulled the codes from my '95 XLT, and it's saying that I have a wrong gear ratio in 4th gear. Could this still be related to the gasket fix that's been discussed, or is this something different?
Thanks!
__________________
1979 Ford Bronco Custom
351M V8
C6 Auto
4bbl Holley 4160
Smog System Removed
Tags
5r55 , 5r55e , 97 , bands , ford , mazda , problems , ranger , replacement , reverse , shift , solenoid , tightening , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
