Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #181 (permalink)
Old 11-26-2007, 07:26 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
yep, lint free is good. newspaper works or else just blow everything off when done wiping. use brake cleaner or an air compresser. i think i used 3-4 cans on my rebuild
props on the vasealine idea, its what you use on trannies. i would suggest putting all of the bolts in before tightening down. make sure u follow my guide to the t! torque settings on the VB is a very very important factor
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #182 (permalink)
Old 11-27-2007, 11:01 AM
karageorge2 karageorge2 is offline
karageorge2 is starting off with a positive reputation.
Instead of using the two separated gaskets can I use the bonded gasket plate instead or will that not work for this valve body?
also what alignment tools are you referring to?
thanks.
George
  #183 (permalink)
Old 11-27-2007, 11:26 AM
fordboy_52's Avatar
the bonded sep plate may not have the right holes in it so i would say no. there are some alignment "pins that you use to hold the gaskets in place. i suppose you could use the bolts.......
Matt
__________________
  #184 (permalink)
Old 11-27-2007, 12:10 PM
OK. I think the bolts will work. Coming to think of it I dont think its anything more precise than that.
Taking the old gasket off the valve body is a PITA. Its seems that its fused on there so I am breaking it off in little f*4%6$ pieces.
I also checked my solenoids and they all were within range.
I am getting harsh long shift times going from 2nd to 3rd and do not think it ever would get into OD.
Probably need to look at the bands too. The first time I changed ATF I did notice a couple small pieces of metal in the old fluid. I did use Mercon III and an Autozone filter. This time Mercon V and filter from Mazda.
We'll see how this goes and go from there.
Last resort would be to order a redone valve body from Rob in Oklahoma (Valvebodies rebuilt place) completely redone solenoids and everything for $229 + .ship.
Thanks so much for all the info. Would never have attempted this without.
I'll let you know how it goes.
  #185 (permalink)
Old 11-27-2007, 04:13 PM
ok, just noticed that the small little metal pieces I had referred to were off the gasket which has embedded little round metal pieces all around. The new one did not have any of these and the old one was too dirty and oily to see. So I do not think these came out of anywhere else. Will probably have this back together either today or tomorow.
  #186 (permalink)
Old 11-29-2007, 03:40 PM
ltlranger ltlranger is offline
ltlranger is starting off with a positive reputation.
My Unique Problem
This one is for Ford Boy. I've read the thread, and I've seen it a dozen times, but seriously, my problem is different. Once my 2002 Ranger Edge 4.0 is warm, it doesn't slip as bad. When I am towing, it doesn't slip at all. However, when the engine and tranny is cold, it slips fiercly from 2nd to 3rd. My engine braking is fine, so I don't beleive its the gasket issue. Any thoughts??My OD light does flash when this occurs.
Thank you to everyone, this thread is great and informative!
  #187 (permalink)
Old 11-29-2007, 03:48 PM
fordboy_52's Avatar
hrm. im absolutly completly a novice on transmissions. i actually found this fix elsewhere on the internet after a week of searching. I cant help you one bit. yours could be a bad selenoid. i have heard that the EPC goes bad after about 50k miles on many trucks. im not sure mine wasnt going bad when i sold my truck. even if they test out, it doesnt mean they are handling the pressures.
when your oil is cold, the pressures are pretty dang hi (if im thinking right) and it might be bypassing somewhere. i would start by replacing the epc and the 2-3 gear selenoids. i know im throwing parts at your problem. but thats all i can do
Matt
__________________
  #188 (permalink)
Old 11-29-2007, 03:53 PM
Hmm...
And let me guess, the epc is also inside the transmission
  #189 (permalink)
Old 11-29-2007, 03:59 PM
fordboy_52's Avatar
its posted further back in this topic. there is a picture showing it. its easily accessable with the pan off. i would do a filter and fluid change while i was in there.
Matt
__________________
  #190 (permalink)
Old 11-29-2007, 06:31 PM
Bob K. Bob K. is offline
Bob K. is starting off with a positive reputation.
Ltlranger,
Temperature was a factor in my blown gasket. I had engine braking in 1st gear when the transmission was cold. Within 10 minutes, I lost engine braking. I suspect higher fluid pressures in a cold engine were the culprit.
If your OD light is flashing, you have a transmission code set. Pull the codes and see what help they can provide.
  #191 (permalink)
Old 11-29-2007, 07:39 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
For those people wondering how the 5R55E actually carries out the shift from 2nd to 3rd gear:
Quote:
Okay, let’s stop and look at what’s going on in the transmission.....in 1st gear, only shift solenoid 1 is energized, which applies the forward clutch. To shift into 2nd, rather than energizing solenoid 2, the computer energizes solenoid 3, applying the OD band. This actually overdrives 1st gear. Then, to shift into 3rd gear, the computer turns shift solenoid 3 off and solenoid 2 on...
So to shift into 3rd gear, the unit releases the OD band and applies the intermediate band. With that in mind, what could happen that would create a flare on the 2-3 shift? Unlike the 4R44E and 4R55E, the 5R55E applies the intermediate band for 3rd gear; not the direct clutch. At the same time, it releases the overdrive band. So if the OD band releases before the intermediate applies, you get a 2-3 flare. The flare is a timing issue; the intermediate band is applying too slowly. Source.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #192 (permalink)
Old 11-29-2007, 07:47 PM
fordboy_52's Avatar
i dont think too many rangers have a 5r55e. 90% of them are the 4r55e.
Matt
__________________
  #193 (permalink)
Old 11-29-2007, 07:52 PM
Rockledge's Avatar
Quote:
Matt
I thought all 4.0L Rangers and Explorers have the 5R55E?
__________________
Ford Pics
  #194 (permalink)
Old 11-29-2007, 08:17 PM
fordboy_52's Avatar
i was told most of them had the 4r55e. but i have been lied to before. i was told that the explorers got the 5r55e and the sports track
Matt
__________________
  #195 (permalink)
Old 11-29-2007, 08:33 PM
Rockledge's Avatar
It's interesting that the 5R55E handles the 2-3 shift differently than the 4R55E. I'm not sure how that bears on the subject (i.e. whether or not the valve body is as often a problem on a 5R verses a 4R model). But it might explain why some people who have adjusted the bands on their 5R55E have experienced better shifting between 2nd and 3rd.
__________________
Ford Pics
Tags
5r55 , 5r55e , 97 , bands , ford , mazda , problems , ranger , replacement , reverse , shift , solenoid , tightening , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
