Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #151 (permalink)
Old 06-17-2007, 11:31 AM
wherermykeys wherermykeys is offline
wherermykeys is starting off with a positive reputation.
hi everyone, first post here...
I've read through this whole post but no one seems to be having the same prob as me. I have a 94 B4000 4.0 2WD...when I shift into D from Park, there's a significant delay of up to two seconds, then it falls into gear HARD. the whole truck lurches no matter how hard I'm on the brakes. It feels the same as if you were to rev it up and then throw it into gear.
It shifts fine once moving, no OD light, no other problems...it just feels REALLY bad when I put it into Drive.
thanks!
  #152 (permalink)
Old 07-22-2007, 08:51 AM
splattered splattered is offline
splattered is starting off with a positive reputation.
95 Ranger transmission problem
Hello to the group, this is my first post. I own a 95 Ranger, 4WD, 4.0L, auto with about 130K on it. I would like to keep it, but the transmission problem is making me want to dump it. The thing will be on the road for about 20 minutes or so, usually on the highway, and it will do what I think is downshift for a moment. The rpm will jump up from around 2k (less if I'm not on the highway) to about 3.5k and them come back down with a jolt. Sometimes it almost seems to come out of gear entirely, not sure. It can happen just once, or it can happen in clusters. It is affected in a big way by outside temperature. The higher the temp, the more likely it is to happen. In fact, in cold weather it does not do it at all. It will happen if the OD is on or off. It will not do it at all if 1 or 2 is selected. Recently got it flushed, and per suggestions from other people I changed the throttle position sensor and vehicle speed sensor. This did not help. What do you think? Big thanks............
  #153 (permalink)
Old 08-23-2007, 09:46 PM
standarla standarla is offline
standarla is starting off with a positive reputation.
Smile Thanks to all in this Thread!
Not knowing much about my '00 Ranger transmission, I got enough info here to adequately assess the possible problem(s). We started noting slippage between 1-2 gears and O/D light starting to flash. DTCs pulled up P0732 and P1756. Fordboy's manual first engine braking test was key to the real problem: a blown valve body gasket.
Not really wanting to be a mechanic, we took it to the local AAMCO, explained the problem, DTCs, and the info we got here on the probable cause. We were ready for the expected diagnosis: "need a rebuild". However, we were quite surprised when they agreed and showed us the torn gasket! Upgrade was done and total parts & labor = $281. Tranny now works great!
Thanks again. You have save us mucho $$$!
  #154 (permalink)
Old 09-08-2007, 01:07 PM
fwadmin fwadmin is offline
fwadmin is starting off with a positive reputation.
I have read this thread and seem to have a different problem. I have a '96 V6 EB with 150K miles. The transmission shifts very smooth however over the past several months I have noticed increased gear grinding noise. My solution was to turn the radio up but lately the gear noise is pretty loud. It is present at all speeds forward and reverse. It's bad enough that I don't feel comfortable driving it now and haven’t taken it anywhere yet. The fluid has been changed (both exchange and drop pan) and the level is correct. Any ideas?
  #155 (permalink)
Old 09-10-2007, 12:46 PM
thomcasey thomcasey is offline
thomcasey is starting off with a positive reputation.
Hello all,
I have read over this thread, and cannot seem to find a reference to my issue. I have a 02 Mountaineer V6 with 95k miles. The tranny shifts fine, no slipping or anything. the issue I am having is once warm, when you come to a stop, and let off the break, you can feel a "bump" from the drivetrain, like the tranny isnt fully downshifted yet. My wife thought the brakes were sticking, but I feel it is the tranny. I did have the tranny flushed 9k miles ago at the dealer. Any idea's?
  #156 (permalink)
Old 09-10-2007, 12:53 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
Quote:
Originally Posted by thomcasey
Hello all,
Something else to consider is a driveshaft issue, maybe a sticky slip yoke, or less likely, bad u-joints.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #157 (permalink)
Old 09-10-2007, 12:56 PM
Quote:
I had thought of that, but cannot find any play, plus it is so smooth when shifting from P-D, R-d, even while moving. Never a nudge or cluck. Everything feels real tight under there. It is just a nudge afetr stopping from driving speeds, and it is only 70% of the time.
  #158 (permalink)
Old 09-10-2007, 01:28 PM
RabidJade RabidJade is offline
RabidJade is starting off with a positive reputation.
I will have to attest that I did valve body gasket replacement with a bonded gasket and found a torn gasket. This didn't fix my transmission problems and now I get about 2 weeks without problems and a few weeks with problems. I think it has something to do with the solenoids since the issue seems to be second gear but I neither have the money or time to have it fixed right now.
__________________
1986 F350XL 460ci 4X4 Auto (non-dually)
2000 Ranger XLT 4X4 ORP 3.0L V6
  #159 (permalink)
Old 09-23-2007, 06:58 PM
rejean rejean is offline
rejean is starting off with a positive reputation.
i wan't to know your opinion about my 5r55e
B4000 2000 4x4 auto
-Hard shift 1 to 2
-no slippage
-no Engine braking in 1 mode
-Sound comming from tranny ( from the front of tranny )
Please help me and
the parts number will be appreciated.
  #160 (permalink)
Old 09-24-2007, 08:50 PM
pbaxter pbaxter is offline
pbaxter is starting off with a positive reputation.
Quote:
Originally Posted by fordboy_52
I am making a sticky for the numerous people with transmission problems. If you own a ranger or explorer you might be experiencing numerous shifting problems. If you would feel free to post here so we can have a running record of problems and multiple people who can assure that we have a correct fix.
I also have a tutorial available for the infamous " valve body " gasket. click the following link
http://www.ford-trucks.com/article/i...dy_Gasket.html
Thanks
Matt
I have replaced the valve body gasket's and cleaned everything per fordboy_52 instructions, but still no first or OD. Also no down shift . I have tried engine pull for first and it might as well be in netural. I can shift to 2 then third they are ok. This is a 1999 Ford Ranger 2.5 4 cyl with 4r44e. I am about to take a wenchester and put it out of my life. Help
  #161 (permalink)
Old 09-26-2007, 07:00 PM
pbaxter to fordboy_52
Where did you get the TSB replacement(mine was kt315p-7m203-ja) Can not fine the upgrade or kit you are showing in your pictures. I did everthing else but the round chome or shiny piston, juust cleaned and replace still no first or over drive. P1747 replaced speed valve on rear drive sharft still no help. I have checked all the valve body soleniods and they check out fine but I still get all the codes P0743, P0743, P0755, and P0760. The wrong mercon was put in but I have remove all from torque and trans and replaced with mecron V. I know the 1st and over drive is there. Help Man in Wylie, Texas digging hole to put this truck in and cover it up.
  #162 (permalink)
Old 09-26-2007, 07:36 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
um, i got mine from ford. you should be able to have a dealership pull up all of the tsb's for your vehicle. contact numberdummby and he might be able to help you as well
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #163 (permalink)
Old 09-30-2007, 06:46 PM
Bob K. Bob K. is offline
Bob K. is starting off with a positive reputation.
Quote:
Originally Posted by gearheadz80
I have a '97 and a '02 4x4 ranger, both 5 speed auto. The '97 just rebuilt by a former ford tech that went out on his own. He said the bonded gasket is now superceeded and is now updated to a thicker plate instead, He found a bonded plate but they are getting hard to come by now. Anyone else hear of this?
Yes. I've done the TSB on two '97 5R transmissions and the separator plates did not come with bonded gaskets. In fact, in the TSB, the part list specifically calls out the upper and lower separator plate gaskets for the '97. TSB 03-22-10 here: http://www.ford-trucks.com/forums/sh...2&postcount=19
  #164 (permalink)
Old 09-30-2007, 06:54 PM
fordboy_52's Avatar
i got a sep plate with bonded gaskets on both sides, much easier and more reliable
Matt
__________________
  #165 (permalink)
Old 09-30-2007, 07:11 PM
According to the TSB, only the '95-'97 model year separator plates require purchasing separate unbonded gaskets. For '98 and up models, there are no separate entries for gaskets: the TSB only lists the separator plate.
From what I gather in all the different threads, I think this implies that only '98 and up separator plates come with bonded gaskets. Separator plates for '97 and older models require purchasing separate gaskets.
For cross reference purposes, here's another thread discussing the same transmission issue: http://www.ford-trucks.com/forums/36...irst-gear.html
Tags
5r55 , 5r55e , 97 , bands , ford , mazda , problems , ranger , replacement , reverse , shift , solenoid , tightening , transmission , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
