Delaware Chapter Join Chapter, Leader: pbsdaddy
))))))........Need Help Finding.........((((((
Old 02-26-2007, 07:13 PM
glruff's Avatar
glruff
glruff is online now
Question ))))))........Need Help Finding.........((((((
So you need help finding something, then post it here.
Be specific, no whatchamacallits, youknowthatthing, or any of demthings.
Somebody surely will have one or know where to get one, hopefully.
Old 02-26-2007, 07:43 PM
glruff's Avatar
glruff
I moved this request here for you Joe, 07F1504X4.
Originally Posted by 07F1504x4
Hey any1 in here with a 06-07 F150?? I have a 07 F150 without skid plates and i would really like to put some on, would going to the ford dealership be good?? or is there aftermarket ones to fit in the stock location?? Thanks
Old 02-26-2007, 07:44 PM
glruff's Avatar
glruff
Brian I moved your response here:
Originally Posted by bd4martin
The FX4 is the only one that I know of that comes stock with any skid plates. I would bet though if you plan to acually need them you would want to consider going aftermarket. You would probably get a lot tougher plate that way.
Old 02-27-2007, 06:25 PM
Mark _G's Avatar
Mark _G
Mark _G is offline
http://www.trademotion.com/partlocat...?siteid=213883
Search under body parts. Put in 2006 (2007 is too new I guess) and F-150. Click Frame. Click Skid Plate. There are three listed, Engine, Fuel Tank, and Transfer Case.
Hope this helps.
Mark
Old 02-28-2007, 10:02 AM
phil6608's Avatar
phil6608
phil6608 is offline
Help!!! lol
Ok I need a parts list to hook up my new amp/subs to my stock system.
Any info would be greatly appreciated.
This is what I ordered.
I would go with this box;
http://www.supercrewsound.com/shop/detail/11/42.htm
I would also go with these 10” subs. They will out perform most 12’s in this box;
http://www.supercrewsound.com/shop/detail/11/495.htm
and this amp;
http://www.supercrewsound.com/shop/detail/11/425.htm
Thanks.
Old 02-28-2007, 04:35 PM
SCRWDRVR's Avatar
SCRWDRVR
SCRWDRVR is offline
"Obsessed"
Phil are you going with an aftermarket head unit or are you using the stock one?
Old 02-28-2007, 05:58 PM
phil6608's Avatar
phil6608
phil6608 is offline
It's a stock 6 disk CD changer head unit out of a Harley truck.
Old 02-28-2007, 06:03 PM
SCRWDRVR's Avatar
SCRWDRVR
SCRWDRVR is offline
"Obsessed"
Ok then other then the amp, speakers and box you need a amp install kit and a adaptor for going from speaker wires to RCA cables for the inputs for the amp. You should be able to pick both up at any stereo place. make sure the kit has some speaker wire and a set of RCA cables.
Old 02-28-2007, 06:23 PM
phil6608's Avatar
phil6608
phil6608 is offline
Ok cool,thanks Brian
