You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hey any1 in here with a 06-07 F150?? I have a 07 F150 without skid plates and i would really like to put some on, would going to the ford dealership be good?? or is there aftermarket ones to fit in the stock location?? Thanks
__________________
George, FTE Chapters Moderator - FTE GUIDELINES
05 F250 6.0 FX4, Innovative Diesel Tunes/10 Expedition EL LTD/12 Explorer LTD EB/13 Platinum F150 EB
The FX4 is the only one that I know of that comes stock with any skid plates. I would bet though if you plan to acually need them you would want to consider going aftermarket. You would probably get a lot tougher plate that way.
__________________
Search under body parts. Put in 2006 (2007 is too new I guess) and F-150. Click Frame. Click Skid Plate. There are three listed, Engine, Fuel Tank, and Transfer Case.
Hope this helps.
Mark
__________________
2006 F350 6.0 -ARP studs-garrett powermax-bulletproof diesel EGR cooler-accufab intake elbow-MBRP exhaust-isspro gauges-dieselsite coolant filter-bilstein 5100 shocks/steering stabilizer (on the front, still haven't gotten the rears yet)-m/t baja mtz tires
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
It's a stock 6 disk CD changer head unit out of a Harley truck.
__________________
Ok then other then the amp, speakers and box you need a amp install kit and a adaptor for going from speaker wires to RCA cables for the inputs for the amp. You should be able to pick both up at any stereo place. make sure the kit has some speaker wire and a set of RCA cables.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
