Ignition Switch Terminals
Check here for starters, and ignition wiring.
Good luck
http://www.autozone.com/servlet/UiBr...3d800ce982.jsp
Good luck
Mil1ion - So here's the deal. I am installing a Painless 18 circuit harness in my 77 F250 and am trying to figure out which wires to install where on the switch. I have 2 battery wires which I will obviously put on the battery terminals. I will put the switched accesories on one of the ACC terminals. What about my coil wires? I installed a HEI style distributor. And what about the wire that goes from the ignition switch to the "S" terminal on the relay? Should I put that one on the ST terminal on the ignition switch?
Old Brown F250
07-06-2015 12:13 AM
alex crease
09-19-2004 11:52 PM
