03 7.3 stalls and misses
I have a 2003 f-250 7.3 over the past few months the truck has stalled at a redlight and has jerked at running speed a few times,does anyone know where i should start to diagnose this problem
uarep
jsnyde17@comcast.net
uarep
CPS maybe?? Check and see if there is some corrosion on the connectors. This is where I would start it could be something else but these are the first to go and the easiest to forget. It could also be a Throttle Position Sensor.
http://guzzle.rbmicro.com/cps.html
First step: make sure the CPS plug is secure. Disconnect and reconnect to ensure that it is making a proper connection.
Then, get yourself a spare cam sensor. They can be had from the dealer for around $150, from International for around $100, or from fleabay for as low as $50.
Check at the bottom of Guzzle's page, click here for information about replacing the CPS
rick2184
12-08-2009 09:29 AM
