seat belt dinger
seat belt dinger
I am about to go out of my mind. My 2000 F-350 powerstroke 7.3 while driving down the road or just sitting and idling will ding telling me my seatbelt needs fastened, even if it is fastened. I tried unplugging the wire under the seat all that did was put the light out on the dash, still have dinging sound. any ideas anyone?
Belt Minder Deactivating/Activating
Preparation
Before deactivating/activating the belt minder, set the parking brake.
Place gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission).
Place the ignition switch in the OFF position.
Close all the vehicle doors.
Unbuckle the driver safety belt
Place the parklamps/headlamps switch in the OFF position.
Turn the ignition switch to the RUN position. (Do not start the engine.)
Wait until the safety belt warning lamp turns off (approximately one to two minutes).
NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
Turn the parklamps/headlamps on then off.
Buckle then unbuckle the safety belt three times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
The following sequence of events confirm the belt minder is enabled :
flashing of the safety belt warning belt lamp four times per second for three seconds
three seconds with the safety belt lamp off
flashing the safety belt lamp four times per second for three seconds again
The safety belt lamp flashing four times per second for three seconds provides confirmation of belt minder disabled .
After confirmation, the deactivation/activation procedure is complete.
Preparation
Preparation
Preparation
Tried to disable the belt minder with no luck. Went through all the steps but the light does not come back on for 3 seconds, after it goes out it doesn't come back on at all.
But the dinging sound does. It is actually making noise while I am going through the steps. wish I could just unplug the box that is making the noise. but I don't think that is possible. ANY IDEAS ANYONE?
thanks Show Dad
thanks Show Dad
Bottom Left of the instrument panel under the seat belt light
Number 24 in this pic
https://www.ford-trucks.com/user_gal...134107&width=2
