89 ranger 2.3 liter 4 cyl. timing or ? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-25-2007, 05:46 PM
btooling btooling is offline
btooling is starting off with a positive reputation.
Hello all,
I have a 89 ford range 2.3 liter 4 cyl. twin coil packs. Replaced the timing belt after a head refurbish. I lined the pointer on the camshaft with the marks on the timing belt cover and I lined the crankshaft groove with the TDC mark on the timing cover, as stated in the "Chilton" book. The spec. sticker under the hood states that ignition timing is 10 degrees before BTDC. I am wondering which setting is correct. The coil pack on the exhaust manifold side is firing but the intake side is not. I swapped the coil packs and they are both good. Any suggestions appreciated.
Thanks
Btooling
Old 02-25-2007, 08:37 PM
Tiggie's Avatar
Tiggie Tiggie is offline
Tiggie is starting off with a positive reputation.
Welcome to FTE!
Are you getting a Check Engine Light?
Just a guess here, but one of the sides is there only for emission purposes and may fire only when the truck is up to normal operating temperature. Otherwise, maybe the wiring going to the coil might be messed up, I'd look at the plug since you've been in that area.
Old 02-25-2007, 09:38 PM
Its my understanding that the plug wires to a cylinder "one from each coil pack" are to fire at about the same time. I have checked the wire plug ends and all look good. I installed new plug wires also. At this point the truck wont even begin to hit. So running it is out of the question.
Thanks for the input
Old 02-26-2007, 10:41 AM
Tiggie's Avatar
How about the ignition module? Have you looked at that?
Old 02-26-2007, 12:04 PM
Ignition module
I removed the DMIS or whatever the Letters are, the module that is mounted near the alternator. The module with the heat conducting compound on the back of it. I was told that a bad one usually has a burned look to the back of it. Mine was like new. I havent done the testing with the digital volt meter, was hoping someone new the answer and would eliminate the need for the Deep testing, which I will start tonight. LOL Not lazy, Just need the truck running.
Thanks again
Old 02-26-2007, 11:08 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
The drivers side plugs do not fire during engine start. This is normal.
For cam timing:
The keyway for the Woodruff key that holds the crankshaft pulley in place should be straight up. This will position the number one cylinder close enough to top dead center for timing purposes.
Align the triangle mark on one of the camshaft teeth with the center mark of the three marks on the rear timing cover.
The crankshaft position sensor is driven by the auxilary shaft and must be timed correctly, or the engine will not start. I think this is your problem. The sensor is in the distributor hole. I can't remember if the auxilary shaft has a timing mark or not, but it will be a diamond on one of the teeth, and will line up with a mark on the top side of the auxilary sprocket again on the rear timing cover. If the sensor has been removed, you will need a special tool to set it correctly. Good luck. jd
Old 02-26-2007, 11:45 PM
Thanks Jimdandy,
Just come from the shop and I tried the 10 degrees BTDC to no avail. I am however getting a good spark on the exhaust side, My aux. shaft does have a white streak of paint on the sprocket I have not seen a mark on the plastic timing cover but will look tommorrow. Your info on the spark help greatly though and I will retime and start looking into the fuel system for insuffecient fuel problems. shewwww at least a place to start from now.
your info is a God Send!!!!!!
Btooling
Old 02-27-2007, 08:24 AM
Quote:
Originally Posted by btooling
Thanks Jimdandy,
Btooling
There is some incorrect information in my post concerning the crank sensor. I was going from memory, and no longer have any info on that model. I will send you a PM with the name of someone who can help you. Sorry for the mix-up and inconvenience. jd
PM sent. jd
Old 02-27-2007, 09:42 PM
Still trying to find the aux sprocket timing specs. Thanks
Old 02-28-2007, 09:39 AM
Finally found my info. 1989 was the first year of DIS. The only thing the auxilary shaft does is drive the oil pump. There is no timing involved of the shaft. It can be placed anywhere on the belt. Just make sure the cam and crank are timed. There is no adjustment for spark timing either. The computer controls this. Again, I apologize for the mix-up. CRS is hell sometimes. jd
Old 02-28-2007, 09:46 AM
Thanks Jim
Jim thanks for your help, I know you went out of your way for a stranger and I appreciate it. Last night I got the timing set back to normal and started the fuel pump search. lol I checked the inertia switch and will check the relays tommorow night, before I "REMOVE THE BED OF THE TRUCK" to get to the fuel pump. lol thats a hoot. ok thanks again God bless you man!!!!
Btooling
Old 02-28-2007, 09:57 AM
Btooling
Not a problem. Glad to help when I can. Does your fuel pump run when you first turn the key on? You will not have any voltage to the pump after the first couple of seconds of turning on the key. jd
Old 02-28-2007, 10:46 AM
BSmitty's Avatar
BSmitty BSmitty is offline
BSmitty is starting off with a positive reputation.
You might try turning the key to on and let the pump run, then (while wearing eye protection) depress the schrader valve on the fuel rail, to see if you have fuel pressure. Also try spraying a bit of carb cleaner in the TB to see if it will fire an external fuel source, before going to the trouble of removing the bed! If you have any fuel pressure at all, and it fires an external fuel source, pull a connector off of one injector and check for a pulse signal. Just a couple things to check...
Old 02-28-2007, 04:20 PM
No, when I turn the key on I do not hear the fuel pump run at all. The truck has been sitting in a basement for a year and a half without running. I figure the gas may have laquered up the pump and made it stick. I turned off all noise makers and all I hear is the clicking of relays and such.
thanks
Old 02-28-2007, 05:54 PM
BSmitty's Avatar
I still suggest you try purging at the schrader valve. Sometimes a pump can run almost completely silently, if you check for pressure then you'll know for sure. I'm not saying you're incorrect in your assumption, but fuel pumps aren't free, the bed doesn't take it's self off, I'd check anyway. Also, check for voltage at each pump when cycling, IE; hook a test light up and turn on the key, see if you're getting power or not.
Edit: I can't remember if '89 uses a booster pump, or has a single high pressure in-tank pump.
'01 ranger misfire/compression test erich545 Ranger & B-Series 54 09-10-2016 03:21 PM
Lima 4 cyl timing thoughts wtroger Ranger & B-Series 1 07-26-2016 09:44 AM
diagram showing spark plug wires to Coil pack? Jose A. Aerostar 7 04-11-2014 01:35 PM
89 Ranger 2.3 5sp manual questions lostnvegas1 Ranger & B-Series 4 02-07-2014 08:33 AM
'94 Ranger - Check Engine Light gbone00 Ranger & B-Series 4 04-08-2004 01:54 PM
Tags
1983, 1989, 23, 23l, 89, engine, fire, ford, liter, ranger, retime, start, timing, truck, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
