I need fuse help! - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
I need fuse help!
Old 02-25-2007, 04:50 PM
pullinair pullinair is offline
pullinair is gaining momentum as a positive member of FTE.
Exclamation I need fuse help!
There are two fuses in the fuse panel under the hood; they are both 7.5? or 75?, amp fuses. the one closest to the front of the truck was blown. What is the blown fuse for?
The fuse positions are #19 (which was blown) and #18 (Which was not blown)
BTW- does anyone have a listing of fusee locations for both under the hood and inthe truck for future reference?
thanks -tim
Old 02-25-2007, 05:12 PM
Anyone have an owners manual?
Old 02-25-2007, 05:17 PM
AustinS AustinS is offline
AustinS is gaining momentum as a positive member of FTE.AustinS is gaining momentum as a positive member of FTE.
I sent you a pm.
Austin
Old 02-25-2007, 06:34 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
thanks -tim
I am abit confused.. the fuses closest to the front of the truck are from left to right #1(7.5A) #2(10A) #20(50A).....#19(20A) is closest to firewall on the left, #18(30A) is just below it...Anyway, thats on my 99. #19 is listed as "Fuel Pump Motor, PCM.
Old 02-25-2007, 06:42 PM
I figured out is was the #1 fuse -trailor tow pakage.
While I was rooting around the panel i found out my truck does not have an A/C diode.
It sits beside the PCM diode, in the under the hood fuse box. I do have air conditioning in the truck if thats what the A/C stands for. Leaves me to believe I am missing that diode. Even if it stood for alt current I should still have one.
Any thoughts?
Old 02-25-2007, 06:50 PM
#36 is "not used".. #37 (bottom right corner) is your PCM relay diode.. Surprised you don't have A/C.. thought everyone had air on their trucks..In looking at all the fuses in both under the dash and under the hood, don't see any listed for Air Conditioning.
Old 02-25-2007, 06:55 PM
Uzumati's Avatar
Uzumati Uzumati is offline
Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.Uzumati has a good reputation on FTE.
Pullinair I have a PDF of both fuse panels if you want it PM me your email address.
Old 02-25-2007, 06:58 PM
Quote:
AustinS hooked me up with a diagram, thanks though.
Wondering why i did not have an A/C diode beside the PCM diode still.
I do have air conditioning on the truck. Am i missing it?
Old 02-25-2007, 07:03 PM
Sorry i miss read your post.. Don't see any listing for any Air Conditioning in the manual in both the under the hood or the under the dash panels.. Wonder how it is protected?
Old 02-25-2007, 07:16 PM
Uzumati's Avatar
Found it. it is the AC Clutch diode. Its not jumped with a piece of wire is it?
It is on the ground side of the AC clutch solenoid. My guess would be someone wire the solenoid straight to ground bypassing the diode.
Want the diagram so you can trace it?
Old 02-25-2007, 09:13 PM
there was a wire coming out of the fuse box when i bought the truck, bt it was snipped and never led to anything. I cant remember if the wire was stuck in the A/C diodes place or not. Do I need to get a diode. Im kind of lost still wether i should have on or not.
Old 02-25-2007, 09:17 PM
Uzumati's Avatar
From the diagram it appears to be there to prevent a back feed of voltage to ground in the event of solenoid failure. Cant really see any other reason for it. If your AC clutch is engaging the solenoid must be getting ground from somewhere
Old 02-26-2007, 12:37 PM
If you are worried about fuse location #36, which is in the front of the box, the second location over from the right, under the hood panel, my owners manual says it is not used. It is empty. Your previous owner must have tap into this location for a accessory.
Old 02-26-2007, 01:59 PM
The A/C clutch will work with or without the diode. The diodes in the batt junction box A/C & PCM are there to protect against any surge which could rarely backfeed through the A/C clutch solenoid and damage any sensitive electronics in the PCM. I would get a replacement for it when you get a chance, but I wouldn't make it a life driving priority. The computer contolled cars and trucks of today are goofy sensitive to any electrical anomolies. Lightning could strike our trucks and 999,999 out of 1,000,000 everything would be fine, but you could discharge a static charge from your fingertip and fry the PCM. Electricity is a strange force. I'm a master electrician, and I don't understand a lot of things I see in a day of service work. Rarely in a 12V direct current electrical system do reverse surges happen, but Ford must have had enough of them happen out of the millions of vehicles they have produced to see it as a cost effective "warranty insurance" policy.
The A/C Diode part number is F57B-14A604-A
Hope that helps ease your mind pullinair,
Austin
No turn signals or hazard lights carlsson 1999 to 2016 Super Duty 1 07-09-2015 06:06 PM
Fuse box Under hood fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 4 09-08-2011 09:49 AM
maxi fuse #18 jimwilsonmasonry 1994.5 - 1997 7.3L Power Stroke Diesel 5 10-19-2009 08:59 PM
Fuse keeps blowing??? NeXtras 1987 - 1996 F150 & Larger F-Series Trucks 5 06-24-2007 05:41 PM
Blown PCM fuse on start up? OrangeF150 1997 - 2003 F150 3 08-08-2005 11:49 PM
Tags
19, 2001, 2006, air, blow, blows, conditioner, diode, f250, f250lariat, f57b14a604a, ford, fuse, fuses, panel, pcm, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
