sandblaster, or wire brush to remove rust?
Received 3,090 Likes
on
Originally Posted by Torque1st
On the other hand a wire brush just seems to smear the rust around.
I would use a sandblaster, from a little further back they don't cause any deformation, or at a lower pressure depending on the machine you are using.
I use a wire wheel then flap disc to remove all the large scale surface rust. If looking for a nice job that lasts then follow with the sand blaster.
You could use Black Beauty (basically black slag), some like glass beads or walnut shells. A steel flatbed is probably 1/4" steel, I do not think you have to worry about overheating the metal with a sand blaster unless you try to use it to drill holes.
Recently used cheap 'pressure blaster' to floor pans, firewall, inner fenders, and various parts and accessories and found it worked well removing the rust. Used a soft, or mild media, and as mentioned, kept nozzle at reasonable distance. If should consider, may want to test beforehand for warpage, may not want to use on dash. Goes without saying, want to make sure weather will permit painting as soon as possible, using what ever products you found works best. As indicated by another member, it's messy with sand in every oriface in the human body, felt like an emery board for couple days. Also, would not suggest blasting in garage or enclosed structure unless don't mind walls, ceiling, storage cabinets, tool boxes, oh yea, and every surface imaginable with coat of media. Came across article using pressure blaster with sandblaster cabinet and it worked great. Found my cheap cabinet/blaster combo a little humorour, couple side effects. Anyhow, had an urge to add my $.02.
dave
dave
Originally Posted by angus
Consider using a sandblaster attachment for a pressure washer. There's no dust, and water is a more efficient medium than air, so it needs less Hp and fuel to get the job done.
I use a good, properly fitted respirator (NOT a dust mask!), with the appropriate filter cartridges, to help avoid any problems later on. This is especially critical when using sand, as silicosis is a quick killer, and even a mild bout with it will leave you laboring for breath for weeks.
cody919
23
08-28-2015 08:13 PM
hazardousdrew
12-11-2003 10:31 PM
