Here is my hillbilly mixer - Ford Truck Enthusiasts Forums
Old 02-25-2007, 12:00 AM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
1 barrel, 1 heating element from water heater, 1 thermostat from a old stove, 1 old outboard drive and finally a electric motor. I just need to wire up the thermostat to the element and rig my pumps to move liquid in and out of the barrel.
Old 02-25-2007, 12:05 AM
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
That's awesome!!
Old 02-25-2007, 01:11 AM
Fordbronco69's Avatar
Fordbronco69 Fordbronco69 is offline
Infidel
Fordbronco69 is gaining momentum as a positive member of FTE.Fordbronco69 is gaining momentum as a positive member of FTE.
Holy Crap.
Old 02-25-2007, 11:07 PM
I dont know if I need to take holy crap as a compliment or insult.
Old 02-25-2007, 11:30 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
Ummmm, wouldn't a small electric trolling motor do just as well? You can pick them up at a yard sale for $10-$40 apiece.....
Old 02-26-2007, 12:47 AM
Yup, but I dont want to give money away. Besides, in Arizona boats go in the water 365 days a year 8 days a week. Trolling motors ive never seen at yard sales and I love yard sales.
Old 02-26-2007, 05:32 AM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Looks like you might need a little bigger prop!! lol
Other then that looks like a great set up!
Old 02-26-2007, 08:04 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
At work we use a pneumatic mixer in our oil drums with an impeller maybe 1/3 the size of the prop you've got there. You are going to have to do a lot of experimenting with the rpms to keep that thing from just tossing the oil over the top of the drum.
Old 02-28-2007, 12:37 AM
Jacksfirstdiesel Jacksfirstdiesel is offline
Jacksfirstdiesel is starting off with a positive reputation.
If you want you could plumb the water pump impeller in the lower unit as a transfer pump to move material to a settling tank while being mixed and warm. What do you think. I just love your setup! I think I've got an old lower unit layin' out back. Better yet- If I could convince an outboard motor to run on diesel I could just drop a fuel line in the tank and fire it up! LOL
Old 02-28-2007, 11:25 PM
Ha ha ha, Im not gonna plumb an impeller from this junk lower. Be too much brain work. I have a fitting in the bottom of the barrel that will go to my second pump. My primary pump is a 2 horse spa pump that moves oil from my 400 gallon tote tank to the barrel. A second moves it from the barrel bottom to my other 400 gallon settle tank. A smaller 3rd pump will move my chemicals mixture to the barrel. Ive just got the last two ideas from Fabman to fab up. A mixer for the chemicals and to find a holding tank that will hold vacuum. I have the vacuum pump already and the total cost is just in my Pvc plumbing.
Air Cleaner for 351m 46Whizzer 1973 - 1979 F-100 & Larger F-Series Trucks 13 02-18-2015 10:25 PM
Drivers heated seat element 1buzzbait WTB - Parts & other 0 03-09-2014 11:53 AM
Anyone replace thier heated seat elements? Spaceman Spiff 1997 - 2003 F150 0 02-16-2010 05:40 PM
Processor wiring question Rushmore X Bio-diesel, Propane & Alternative Diesel Engine Fuels 25 01-24-2010 06:25 PM
thermostat ???? 77fordguy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 14 10-27-2005 01:14 PM
Tags
billy, heater, hill, hillbilly, margarta, mixer, motor, outboard, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
