97 F250 Front rotor change question
Old 02-24-2007, 03:17 PM
djf48's Avatar
djf48
djf48 is offline
Ok, I want to replace my front rotors and I'm wondering if I have to take off the front hub. If so, what would it take to do that?
Thanks
Doug
Old 02-24-2007, 03:27 PM
titusf350's Avatar
titusf350
titusf350 is offline
4wheel drive or 2 wheel drive?
Old 02-24-2007, 05:20 PM
Striker711's Avatar
Striker711
Striker711 is offline
If its four wheel drive you have to diasemble the whole hub to get the rotor off. You will need a special socket to do the job ( I got mine at Napa), their are two different ones that I know of. Depending on if you have auto hubs or manual. Kind of a pain in the butt job but if you take your time its not that hard. If its two wheel drive I am not sure what you have to do.
Old 02-24-2007, 06:32 PM
djf48's Avatar
djf48
djf48 is offline
It 4wd. I got the caliper off, but still trying to figure out the hub
Old 02-25-2007, 01:34 AM
shanett306's Avatar
shanett306
shanett306 is offline
pound the wheel studs out with a hammer and a punch then the rotor will seperate from the hub. Put the new rotor on the hub set all the wheel studs in place and hammer and punch them back in.
DW SD
12-03-2014 09:00 AM
Doug F
Colorado Chapter
10-21-2009 10:38 PM
Firemudder
04-13-2007 12:48 PM
doug2000
10-09-2006 09:04 AM
Quick Reply: 97 F250 Front rotor change question
