97 F250 Front rotor change question - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-24-2007, 04:17 PM
djf48 djf48 is offline
djf48 is starting off with a positive reputation.
Ok, I want to replace my front rotors and I'm wondering if I have to take off the front hub. If so, what would it take to do that?
Thanks
Doug
Old 02-24-2007, 04:27 PM
titusf350 titusf350 is offline
titusf350 is starting off with a positive reputation.
4wheel drive or 2 wheel drive?
Old 02-24-2007, 06:20 PM
Striker711 Striker711 is offline
Striker711 is starting off with a positive reputation.
If its four wheel drive you have to diasemble the whole hub to get the rotor off. You will need a special socket to do the job ( I got mine at Napa), their are two different ones that I know of. Depending on if you have auto hubs or manual. Kind of a pain in the butt job but if you take your time its not that hard. If its two wheel drive I am not sure what you have to do.
Old 02-24-2007, 07:32 PM
It 4wd. I got the caliper off, but still trying to figure out the hub
Old 02-25-2007, 02:34 AM
shanett306 shanett306 is offline
shanett306 is starting off with a positive reputation.
pound the wheel studs out with a hammer and a punch then the rotor will seperate from the hub. Put the new rotor on the hub set all the wheel studs in place and hammer and punch them back in.
new salt flats by American Racing on '51 F1 DW SD 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 12-03-2014 10:00 AM
***Old Doug Thorley header catalog???*** AerostarDad 1973 - 1979 F-100 & Larger F-Series Trucks 0 06-10-2013 07:01 PM
Old Truck "Sniffer test"??? Doug F Colorado Chapter 4 10-21-2009 11:38 PM
Doug Herbert cams and lifters Firemudder Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 04-13-2007 01:48 PM
changing my front end doug2000 Excursion - King of SUVs 13 10-09-2006 10:04 AM
Tags
1997, 2003, 97, change, changing, drive, f250, f350, forum, front, hd, replacing, rotor, rotors, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
