89 Bronco Rear window Switches - Ford Truck Enthusiasts Forums
Old 08-31-2002, 04:04 PM
Mac55 Mac55 is offline
Mac55 is starting off with a positive reputation.
The Back window will not go up or down?
The key and the panel both will not operate the window
the two 30 amp fuses tested OK
I tested the motor it works great.
I have power to the black and light blue wire but not the black and white one?
Coult it be the tail gate closed switch?
Old 09-02-2002, 09:20 AM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
I had I problem sorta like that one on my 93 it turned out that it has a connector under the rear bumper and it had corroded up, try finding it and cleaning it out, i think its white.
96 Bronco, Eddie Bauer, 351w, Auto
Old 09-03-2002, 07:39 PM
BroncoScott BroncoScott is offline
BroncoScott is starting off with a positive reputation.
I had that problem, I always had to slam the gate to make the latch switch work. I replace the plastic striker bushings and all better.
Old 09-04-2002, 07:37 AM
countryboy29 countryboy29 is offline
countryboy29 is starting off with a positive reputation.
My was do to a broken wire, dont know but it was the rubber seleve with all the wires
Old 09-06-2002, 03:09 AM
1988XLT2002 1988XLT2002 is offline
1988XLT2002 is starting off with a positive reputation.
had a problem too, theres a mercury switch which was broke so the switches would not work because it thought the tailgate was down incase the window wont work with it down, so check that see if that works, if not check and trace back your wiring.
Old 10-02-2002, 12:28 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
If the wiring is the same as my '92, there are only three places to break the window circuit. 1) the dashboard and key switches 2) the fuse and 3) the driver's side latch switch which is meant to keep the window from moving when the gate is down. If the driver's side latch does not fully engage on its post in the jamb or the latch is dirty or damaged the switch may not engage and keep the window from moving. There is a two wire grey connector that plugs into the switch inside the tailgate on the driver's side latch.
Old 10-02-2002, 12:51 PM
Pantherchuk Pantherchuk is offline
Pantherchuk is starting off with a positive reputation.
The switches may be in the LATCHES - these have to be looked at first if BOTH circuits are faulty.
The switch at the dash provides the GROUND for the window motor when the KEY switch is used, as they are GND on both side of the switch when in detent position.
The BLACK and WHT wire is the 12V source for the 2 position KEY switch. ALso look at the connector that should be behind the driver taillight assmbly. Its a good point to test for the 12V.
The two switches - the Dash and the Key have their OWN power source from 2 separate CBs (circuit breakers), not fuses.
IF both switches do not operate the window - chances are your latch switches are buggered or a wiring fault. You have to do a continuity check of all wiring.
Don't discount a bad motor.
I hope some of this helps.
Old 10-02-2002, 12:52 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Old 10-02-2002, 03:41 PM
Bronco AR Bronco AR is offline
Bronco AR is starting off with a positive reputation.
My rear window in my '90 will only roll down, but not up. It was woking fine, and then quit going up. Anyone know what could be the cause? To roll it up, I had to run a wire to the battery, ground another, and touched them to the connector in the tailgate...
Old 10-02-2002, 10:15 PM
rhinomt rhinomt is offline
rhinomt is starting off with a positive reputation.
I had the same problem. Unfortunately I can't offer any other solution other than what I did - sell the 89 Bronco for 500 cash and change my phone number and move.
Old 10-03-2002, 10:55 AM
JBronco's Avatar
JBronco JBronco is offline
JBronco is starting off with a positive reputation.
If the dashboard switch is shorting out inside itself, then neither the switch nor the tailgate key will work the window. I fixed my dashboard switch by taking it apart and bending the tabs. It was a while ago and I don't recall exactly how it goes, but I figured it out by looking at it. If in doubt, you can replace the switch. Also, the dashboard switch can be a source of the window going down but not up, or vice versa, if it is only shorting on the "up" side or the "down" side. Take it apart and you will see what I mean. You can keep it plugged in while it is apart to see how it operates, just don't short it across the leads or you will blow the fuse.
Old 10-03-2002, 03:19 PM
The dashboard switch is a toggle that toggles power to the window motor - One way to raise, the other way to Lower. When the switch is in REST position, it provides the GROUND path for the KEY switch in the tailgate, which also does the same thing as the DB switch, but the electric motor uses the GND path through the DB switch.
It sounds like the switch is broken or defunct. Change it, or jumper it to test it.
A VOM is a handy tool to do this and other tests.
hope this helps
Old 10-03-2002, 05:02 PM
JBronco's Avatar
Again, if you look inside the switch, you can see how it works. There are two sets of contact points (they look like ignition points). One set is for up, and one for down. The flexible copper that the points are on gets bent over time, and can cause symtoms like having to press real hard on the switch to get the window to move, or the dash switch working and not the tailgate switch, or only going up or down. If you look at how the switch works, you can bend the points back to their proper positions. I did this and have never had any trouble again from my switch. At first, I bent one of the sets to far, and shorted it across. It worked fine, but caused the tailgate switch not to work. So watch for this.
Master Window Switch (FIXED) Whitey Ford 1999 - 2003 7.3L Power Stroke Diesel 8 06-15-2015 09:20 AM
Driver's side power window motor Methodical_1 1997-2006 Expedition & Navigator 13 03-29-2012 01:46 AM
Rear Power Window Goes Down, But Not Up jackiegibson 1997-2006 Expedition & Navigator 3 06-24-2010 06:57 PM
1988 Bronco II Power Windows mantta Bronco II 4 11-03-2007 08:55 PM
highlights from installing a power sliding rear window. Eric Landstrom 2004 - 2008 F150 9 04-15-2007 09:00 PM
Tags
89, 96, back, breaker, bronco, circuit, ford, fuse, location, rear, roll, switch, window, wont, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
