Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers And 5th Wheels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Towing, Trailers And 5th Wheels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-23-2007, 09:13 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CUSS
1989 Ford Ranger
Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation Greywolf has a superb reputation
Special Tools and Test units
I took a TOW VEHICLE END seven way plug, and modified it like this:
FROM THE 12V connection, I began running jumpers - first to the running light contact.
From the running light contact I added a jumper to the reverse light contact.
From that - I ran two wires.
One goes to a long extension wire (two conductor) with a switch (momentary on) and back to the brake connection.
The other comes out of the connector to a spade connector for a turn signal flasher.
A turn signal flasher is added.
A second spade connector is on a wire going back in from the flasher to the left turn and brake contact.
The left turn and brake is jumpered to the right turn and brake.
What I have now, is a device that can be plugged onto the trailer seven way that will use the trailers own battery to light up the running lights, flash the turn and brake lights, light a reverse light if the trailer is so equipped, and gives me a switch to check the trailers electric brakes.
Diagram to follow...
~Wolfie
PS: I built it to use as a shop tool. Price? About eight bucks, not including wire and connectors.
__________________
2009 FTE Online CHAMPIONSHIP
FINAL ROUND of COMPETITION
  #2 (permalink)
Old 02-24-2007, 10:15 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
Hoppy's is kind of expensive, but for as much as I use them at work, they were worth every penny.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 02-24-2007, 11:04 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
I can build that kind of stuff!
- I was a NAVY electronics tech for twenty years...
Besides, with a SNAPON tool chest as big as I bought - there are drawers I have not even OPENED yet!!!
__________________
  #4 (permalink)
Old 02-25-2007, 09:21 AM
horsepuller's Avatar
horsepuller horsepuller is offline
horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation horsepuller has a superb reputation
Thanks for the cool tip, Wolfman!
__________________
Scott
Forum Guidelines
  #5 (permalink)
Old 02-25-2007, 12:18 PM
firesoutmatt's Avatar
firesoutmatt firesoutmatt is offline
firesoutmatt is starting off with a positive reputation.
You have way to much time to think of something as cool as this .
__________________
05 F-250 CC SRW LB 4x4 6.0 Tow Command Lariat Remote Start All Stock 01 Alfa 40' Toyhouse for all the toys.
I'm doing my part to reduce our dependency on foreign oil and clean up the environment; my truck runs on 100% biodiesel made from soybean oil grown by U.S. farmers. What are you doing?
  #6 (permalink)
Old 02-25-2007, 02:46 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
I don't have enough time - that's why I built it...
Instead of using a simple jumper and walking around a trailer 6 times, I can make them all work at one shot, and even test the brakes!
I did it in such a way that no contact has more than two terminals connected, so that it fits in the shell better. Leave the jumpers long - you'll still have to cut out the back of the plug for room. Loop them right on out and back in.
I used spade connectors for the flasher unit so that it can be easily replaced if it goes bad.
__________________
  #7 (permalink)
Old 02-26-2007, 09:15 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
I'm also thinking of adding a "GROUND TEST POINT" to the ground contact, so I can test for bad grounding.
"Be thorough, it pays off"
__________________
  #8 (permalink)
Old 02-27-2007, 07:52 PM
ReAX's Avatar
2002 Ford F-250
I don't know how electrically inclined you are, but in my trailer side hoppy box, there is an Ammetre. Its 2 amp per LED, and is very handy for checkling load. It makes it easy to see if one side is pulling more load than the other, or if it's shorting out.
__________________
  #9 (permalink)
Old 02-27-2007, 10:43 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
I have an ammeter that can be held against a wire to see current draw.
I nabbed it right out of the parts store for dirt cheap!
It's about the size of a pack of smokes cut in half the long way.
__________________
  #10 (permalink)
Old 03-04-2007, 10:03 PM
hdway hdway is offline
hdway is starting off with a positive reputation.
Install a small pilot light between your 12 volt charge circuit terminal and the ground terminal if it lights up the trailer ground is OK and you have power.
  #11 (permalink)
Old 03-04-2007, 11:15 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
Any way you can simulate operating conditions and have test points is a good test rig.
__________________
  #12 (permalink)
Old 06-20-2007, 01:30 PM
partsman01's Avatar
partsman01 partsman01 is offline
partsman01 is starting off with a positive reputation.
How about a picture for us that need visual help?
  #13 (permalink)
Old 07-08-2007, 02:32 AM
Powerstroker_18 Powerstroker_18 is offline
Powerstroker_18 is starting off with a positive reputation.
We built a tester for testing the truck side of the towing equation it's just an old metal "briefcase" that we put 7 marker lights and glued 4 magnets inside to simulate a trailer. It's got about an 8 foot lead with an rv plug on it and there's enough room inside the box to store all of our adapters to do cowboy plugs and 4 pins. Pretty cheap compared to those expensive emulaters, But better than the cheapy ones.
  #14 (permalink)
Old 07-09-2007, 02:22 AM
cangim's Avatar
cangim cangim is offline
cangim is gaining momentum as a positive member of FTE. cangim is gaining momentum as a positive member of FTE.
You could also drop by radio shack and pick up a large plastic project box to mount it all in. Then setup some toggle switches with LED indicators to see what you are turning on. the flasher and momentary switch for brake lights as well. If you really wanted to be fancy setup your ammeter and voltmeter display on the box as well. If it is setup right for 7rv, then with appropriate adaptors you'd have the rest of trailer connectors set. For the flat style you'd need a battery or 12V source. I haven't made one yet but I just might as I have all the stuff to do it. It would make fixing other's trailers quicker. One key point as this would be a test setup and you really don't know what your plugging into. Use a resetable fuse link in the box, a 10A should be more than sufficient but go with what you want.
__________________
http://www.ford-trucks.com/user_gall...id=153297&.jpg
Wishin I was still camping somewhere....
-Mike
  #15 (permalink)
Old 07-09-2007, 09:56 PM
Greywolf's Avatar
WILD CUSS
1989 Ford Ranger
Let's think about what the several connections do.
Some of then you want to be able (with a test rig) to turn on or off. That pretty much says we need toggle switches.
Selectable power from either the RV battery, or an outside source. A cut-off jumper cable works for the connection to a spare battery.
It should be able to select brake lights, turn lights, reverse lights, running lights, and have a potentiometer for a brake signal, or a full-on, full-off toggle switch.
Seems like a simple project to me.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
