Can I use fiberglass tank for bio?
Old 02-23-2007, 03:04 PM
Hotwheelbill's Avatar
Hotwheelbill
Hotwheelbill is offline
I got some good free stuff!! 100,200, and 300 gal. fiberglass tanks with pluming and pumps. Can I use this for making bio?
Old 02-23-2007, 08:31 PM
Hotwheelbill
Sorry for the dup. Please remove.
Old 02-24-2007, 10:53 AM
mongo75's Avatar
mongo75
mongo75 is offline
Yes you can. I've seen glass used for both gas and diesel fuel on a boat, where you definitely want the safest situation. Just make sure that being a used tank, that they hold pressure, I'd try to test them to no more that 2 psi.
Old 02-25-2007, 05:38 AM
Hotwheelbill
Old 02-25-2007, 01:10 PM
Murphy2000's Avatar
Murphy2000
Murphy2000 is offline
The fiberglass is compatable with biodiesel but sometimes the resins used to soak the glass fibers are not. You'll need to test it. There are several types of glass resins that are used and if you get the wrong one, the bio will dissolve your tank within a few days and spill everywhere.
2nd, All fuel holding tanks should be steel. Using a plastic tank of any type is sort of asking for problems.
Old 03-21-2007, 08:34 AM
michaelbrainardatwor's Avatar
michaelbrainardatwor is offline
Ethanol blended gasoline has been causing problems for owners of older boats with fiberglass tanks - the ethanol is said to attack the resin in the fiberglass tanks....goey resin is plugging up filters and fuel systems....and eventually leaking.
Yes...this is ethanol, not BD...but I would be very careful.
greeneyes43
6.4L Power Stroke Diesel
18
07-06-2014 08:04 PM
eltonmcrae
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-02-2011 12:32 PM
horser72
03-07-2008 09:55 PM
sand1
01-09-2008 05:02 PM
bio-d
04-13-2006 12:40 PM
Quick Reply: Can I use fiberglass tank for bio?
