1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
E350 transmission problem
Old 02-22-2007, 08:10 PM
allenrandle's Avatar
allenrandle
allenrandle is offline
1994 E350 with a E40D transmission. Problem: will not shift from second to drive or overdrive most of the time. However, some of the time it shifts correctly. The yellow light on the gear shifter is on sometime and sometimes it is off. What is the problem?
Need help.
Thanks,
Allen
Old 02-22-2007, 09:34 PM
redford's Avatar
redford
redford is online now
Received 1,564 Likes on 912 Posts
Hi allen, welcome to FTE.
The E4OD is controlled by a computer. I would start by seeing if there are any error codes stored, then go from there.
Old 02-23-2007, 07:18 PM
allenrandle
Unhappy Reply
aTransmission shop says there is nothing electronically wrong with it, but if nothing is wrong, why would the light be flashing. Tried using scanner; it would go so far and give no information. I have a nemesys scanner, but cannot receive any information out of it. Don't know what to do now. I know for a fact that there has been at least three transmissions; vehicle has 160,000 miles. What would cause a minimum of three transmissions to go bad on this vehicle?
jpatt504
02-27-2017 08:37 PM
4.9Inline6e4OD
06-18-2016 01:46 PM
Stephan Acevedo
12-11-2015 12:12 AM
198769ford
10-03-2012 08:16 PM
scottw1
01-16-2009 04:17 AM
Quick Reply: E350 transmission problem
