5.4 cam phaser - Page 6 - Ford Truck Enthusiasts Forums
5.4 cam phaser
  #76
Old 06-20-2013, 10:50 AM
Mitch Court Mitch Court is offline
Mitch Court is starting off with a positive reputation.
Cam Phaser
Ok I've read and watched about half a dozen blocks of instructions on how to replace the phaser in my 5.4 04 F150. I dont see where they are placing the timing block to keep the chain slack out. I went ahead and purchased both sides "phasers" where in the heck does the wedge tool go? anyone have a photo for me to look at?
SSG Court
Infantry, US Amy
  #77
Old 06-21-2013, 01:27 AM
tylerclay tylerclay is offline
tylerclay is starting off with a positive reputation.
Basically your just jamming the wedge down between were the chain narrows in the timing cover. all you want to do is jam the chain in such a way it wont fall down and come off the lower sprocket. If it does fall you will need to remove the front cover which actually isn't that hard, an extra hour is about all. I've had mine apart way too many times to count. Did you do an oil pressure check before starting this job? And the check done with a manual gauge, not the one on your dash?
  #78
Old 07-16-2014, 02:48 PM
Tigauto Tigauto is offline
Tigauto is starting off with a positive reputation.
Cam phaser
You can go on alldata and buy the licence for all the information on your truck.
I think it's about 19.00 last time I checked, I'm a tech and alldata is what we use.
I would like to add check your oil pressure first before forking out money for parts. The 5.4 and 4.6 are known for the tensioner blowing and causing oil starvation to the top of engine. This causes the phaser problems in some cases not enough oil pressure. Not saying this is your problem but better to be safe then sorry. They are also bad for VVT screens plugging up or coming a part
How to Save Installing 18 of 24 Followers on a Timing Job. macubus 2004 - 2008 F150 3 01-17-2017 10:32 AM
Just bought a 04 Ford F150, Ticking noise? DJayAce 2004 - 2008 F150 10 12-19-2016 03:24 PM
5.4 3V expert advice needed to replace phasers vs whole rebuild? 66 bronco roadster 1999 to 2016 Super Duty 49 08-12-2016 11:32 AM
VCT solenoids or cam phasers? heatseaker1 2004 - 2008 F150 2 12-28-2012 04:51 PM
2005 F250 5.4 Cam Phasers HELP !!!! thomas_e102 1999 to 2016 Super Duty 13 09-05-2010 12:05 PM
Tags
2004, 54, cam, cammed, changing, f150, ford, noise, phaser, phasers, phazer, quiet, recall, rotunda, timing, triton, wedge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
