You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Ok here is what i found about my rig verses a comperably equiped 6.0( CC Long box 6 speed 4x4) the 6.0 is faster out of the hole, but doesn't take long for me to catch up and pass. I believe I am faster in a 1/4 mile because I'm passing him at about 60 mph. Another thing. From about 50 mph up, I don't downshift hardly ever to either pass or race. you can't do that in a 6.0. That motor loves RPMS. Once that boost comes alive in my 7.3. . . . my buddies 6.0 cant hold on. We'll get a further report when I do my compound turbo.
Tim
__________________
Tim
2000 F-350 CC LB 4x4 6 spd Hmax: headgaskets, valve springs and stage II singles. back to H2E, Terminator Big Oil, Dp tuner, CPRX fuel system, oil bypass kit, Ceremetalic clutch, Procomp 6.5" lift, 05 Front end, 37's on 20's. Guages.
__________________ 2006 KR 6.0 4X4 Navigation SYS and 20" Wheels
Torque shift all the bells and even a whistle
Bulletproofed at 40,000 miles.
2001 Super Crew Lariat F150
5.4 Auto 4X4
Past trucks 87,88,91,93,94,96,97,99,03 all Fords!!!!
Well, your sig line is pretty long, what does your friends sig line look like? That will tell more of a story. All things being equal, the 7.3 which has a larger displacement should have a flatter torque curve at crusing speed.
__________________
My name is Ryan and I work for BIG OIL, which allows me to comfortably afford.........................
Luke, nope, don't hate them, just tired of hearing how much more superior to the 6.0 they are.
Now on to the original post, If you think that a compairable equipped 6.0 (larger injectors, better fuel system, SCT tuner, exhaust) will lose to a 7.3, well then, I think your just an idiot, plain and simple, thats not hate, it is just a fact.
__________________
Hiflyer746: I also noticed you have a 6 speed. I guarantee you if you put your truck up against a similarly modded 6.0 with a torque shift you wont keep up with it....
5.4 Auto 4X4
there are a few 7.3 haters. My friends I told you that it was a comperably equipted truck. CC LB 6 Spd 4X4. He has a 175 HP custom Mach 7 from hypermax. Thats also why I said his truck will beat me off the line. . . but I will beat him in the long run. I don't mince words or lie to win. I either win or loose. There is no doubt that it takes a hell of a lot more money to get a 7.3 to win over a 6.0. And yes a 6 speed against an auto requires about 100 more horse to be competitive. All I'm saying is that when my engine breathes. . . . . it really breathes. The 6.0 just needs more RPM to breathe like mine.
Tim
__________________
Tim
One more thing I forgot. . . . our truck are the same down to the gears and the tire size. The only difference is what is bolted to the front of the tranny.
Tim
__________________
Tim
I not ABOUT to get into a 6 vs 7.3 discussion when LukeCline is in the thread
Talk about comparing vw's to corvette's
BUT.... stock to stock the base 7.3 is rated @ 235 hp ? the 6.0 @ 325 ?
'splain to me how the extra displacment makes up for 90 HP difference ?
Promise you I've had both, stock - tuned - whatever...
"similarly equipped" there's not much of a contest....
unless the driver of the 6.0 is not much of a driver
And from your friends choice of chips, I would be concerned that that 175 HP chip is not really 175 hp
Ya know years ago when I got old enough where all I could do was pitch...
I had a no-hitter in a slow pitch softball tourney...
while I usually threw hard to hit stuff... it's STILL slow pitch
says more about the other team than my pitching
__________________
13 F-350 Platinum 6.7 CC SB Tuxedo Black Metallic 11.5k gvwr,
13 Explorer Sport 3.5 Twin Turbo 365 hp Ecoboost Tuxedo Black Metallic.
12 MVP Destiny 355RE 5th wheel
gone-12 F-250 6.7 CC SB Sterling Grey Metallic Lariat w/ Ultimate Pkg. MBRP filter back Exhaust, Airlift air bags.gone-05 Ex 4x4 6L,even goner-2002 4x2 7.3L Ex Limited
well i cant remember wat year it was up'ed power, but the 7.3 id make 250 hp and 520 lbs wen it did leave. but if its a 2000 model year then yeah it was 235 horses. but the 6.0 does have 32 valves comparing to the 7.3s 16 valve so keep that in mind.
__________________
95 F250 std cab long bed XLT 7.3 PSD 5sp 4x4 with D60 swap 4.10 gears 140k
89 F150 std cab long bed XLT Lariat 300L6 EFI 5sp 4x4 factory quad shocks 3.55 gears 180k
83 Ranger std cab long bed 351W Fmx auto 2wd
87 F250 std cab long bed Custom 6.9 idi 4sp 4x4 4.10 gears 190k
Tim
You are one in a million. Go buy a lottery ticket.
Blah Blah Blah....Running a 7.3L against a 6.0l will not prove anything, the 7.3 is reliable but not as efficient as the smaller but more efficient 6.0L. Every engine get phased out with time and upgrades in technology, why cant people just realize that?
Oh and before I ever see another "7.3L is crap compared to the 6.0L"...I want to see approved and documented test results showing the differences instead of people just lieing out there AZZ.
Well don't the 7.3 make more power with all the aftermarket goodies on them? so doesn't that show right there that newer is not better in all cases? i'm pretty sure like the top 5 fastest powerstrokes are 7.3's
The 6.0 with a good tuner and exhuast will make more power then a 7.3 with 5k worth of turbo and injectors, it is new tech versus 20 year old tech, plain and simple. The 7.3 is a simpler, bigger, slower turning motor which may expain it's longevitiy.
