Competition Diesel racing, sleds, dynos, power tuning and max performance.
Traction bars and tuner question
Old 10-25-2007, 12:02 PM
floridahonky's Avatar
floridahonky
floridahonky is offline
Need some advice here fella's. I have an 05 250 PSD with 6" of lift. Rear lift is blocks. Getting ready to order the XCAL3 from Matt and some of his mild tunes. Should I be concerned about the added power and axle wrap with NO traction bars. Maybe I am paranoid but it seems like the added lift using blocks is not a sturdy setup.
Thoughts?
Old 10-25-2007, 12:26 PM
mac48370's Avatar
mac48370
mac48370 is offline
Hey
i have a 06 will a 6" lift with springs though but even stock if i backed out of the drive way i would get it hoping i put procomp bars on it and they work great i got all the banks stuff no wheel hop at all
Old 10-25-2007, 12:30 PM
WWBeast's Avatar
WWBeast
WWBeast is offline
can you add blocks and with a spring lift, i have a stage two procomp 6 inch.
Old 10-25-2007, 01:03 PM
mac48370's Avatar
mac48370
mac48370 is offline
yea you can i have a bds 6" and i could have left the stock block out to make the truck level our put it in like i did to make the rear higher....but i could have used an even taller block to make it higher yet....just dont stack blocks on top of each other....since you used just blocks i would recommend the traction bars the taller blocks will put more stress on the springs and make even more wheel hop....i got mine on ebay bran new for like $280
Old 10-25-2007, 01:55 PM
WWBeast's Avatar
WWBeast
WWBeast is offline
ya see i always thought you could but when i called down to 4wheel parts they said first off they dont make them for fords anymore... which made no since and then they said they couldnt do it haha, so i just got the suspension 6 inch
Old 10-25-2007, 01:56 PM
floridahonky
ok, I can deal w/ some hop until I can get the traction bars added. I was more concerned about the added torque rolling the axle far enough to spit the blocks out and loosing the axle.
like i said, just paranoid.
Old 10-25-2007, 08:43 PM
MrMike06's Avatar
MrMike06
MrMike06 is offline
I have 4in blocks on my truck and I have some axle wrap, but it feels the same to what stock was. I wouldn't worry if your not going to race where your doing 15psi drag launches. I've done 4 wheel launches, burnouts and 50 mph beach cruises with no problems (knock on wood), so I think you will be fine.
Old 10-25-2007, 08:50 PM
18vtx00's Avatar
18vtx00
18vtx00 is offline
make sure your U-bolts are tight, get the ultra comp and agressive st.. you'll love the higher tunes once in a while
Old 10-25-2007, 10:53 PM
gross30's Avatar
gross30
gross30 is offline
I put a set of pro-comp traction bars on, and it sure helps the wheel hop on rough roads. I am pleased with the purchase.
Old 10-25-2007, 11:25 PM
LvTitan's Avatar
LvTitan
LvTitan is offline
yes you will want to get traction bars. i have a 6" lift, but i have springs also, so the only additional block is a 2" aluminum lift block along with the factory cast piece.
i have XCALII with some of SDT's hotter files, and i have SERIOUS issues with axle wrap, i am in BAD NEED of traction bars. ! ! !
Old 11-15-2007, 05:11 AM
benwill1's Avatar
benwill1
benwill1 is offline
I busted an alum block....be careful
Old 01-25-2010, 01:00 PM
MacbooknMyTruck's Avatar
MacbooknMyTruck
MacbooknMyTruck is offline
I am soon to be running a 2.5" leveling kit, and a custom tuned SCT. Will traction bars help at all, or are they even necessary?
Old 06-12-2010, 12:19 PM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
Check out Jesse's at farmboyfabrications.com He has an incredible traction bar set up. I have one of his first sets and its now called the stage one. I pull with my truck and have no issues. In fact it cured all the vibration i had.
emmagator
1999 to 2016 Super Duty
16
11-04-2008 07:46 PM
klemklubfoot
08-19-2008 01:50 AM
emmagator
03-10-2008 09:18 AM
emmagator
03-09-2008 09:17 AM
FordGuy0131
21
08-23-2007 10:20 PM
Quick Reply: Traction bars and tuner question
