Tire pressure? - Ford Truck Enthusiasts Forums
Tire pressure?
Old 02-22-2007, 09:55 AM
hellbent hellbent is offline
hellbent is starting off with a positive reputation.
Tire pressure?
I have a 97 F-150 short box. I bought a set of Goodyear Wrangler AT/D2 tires from Sams this a.m. (265/70/R16, up 1 size from stock). Where should I run the inflation for a decent ride and good tire wear/mileage? Door tag says 29 psi front and 32 psi rear. This seems to low. Thanks!
Old 02-22-2007, 10:55 AM
skilife17's Avatar
skilife17 skilife17 is offline
skilife17 is starting off with a positive reputation.
I have Pathfinder Trail A/P's on my truck and have them set at about 5psi below the max on the tire. My door says the same on my 97 as yours hellbent. My tires are 255/70 R16
Old 02-22-2007, 12:09 PM
laketrout laketrout is offline
laketrout is starting off with a positive reputation.
When I take mine to the dealer for service, they always set them to 32.
Old 02-22-2007, 12:19 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
I keep my 285/75/16 Destination M/T's at 35psi all the way around.
Old 02-22-2007, 12:39 PM
trailor trailor is offline
trailor is starting off with a positive reputation.
i got the same Goodyear Wrangler AT/D2 tires from sams, but i got the 255's... the tires say max psi is 44 and i have them right around 40 and have a pretty damn smooth ride, i wouldnt think goin down into the 30s would be such a great idea, may cause additional wear n tear. IMO i'd go with what the specs on the tires are and not the specs on the door, considering those aren't the same tires it comes with stock
Old 02-22-2007, 06:11 PM
I had Sams set them up A 38 psi front and back. It's hard to get anyone to commit to "real" advice due to liability and whatnot. At this point I'm trying to get the most mileage and reasonable handling out of the tires. Thanks all for the replies!
Tire PSI stydel311 1987 - 1996 F150 & Larger F-Series Trucks 7 05-04-2014 11:48 AM
Can anyone recommend a decent tire pressure gauge? asok 1999 to 2016 Super Duty 23 06-22-2011 08:30 AM
Tire pressure XBAJBUSX 1994.5 - 1997 7.3L Power Stroke Diesel 6 08-22-2010 11:00 AM
P255 tire psi? blue2golf 1997 - 2003 F150 2 09-05-2005 11:47 PM
Tire PSI 4 BFG Rugged Trail? Sagegrouse Excursion - King of SUVs 5 02-10-2005 02:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
