2001 4.2L Exhaust Rattle at low speeds - Ford Truck Enthusiasts Forums
Old 02-22-2007, 02:35 AM
drlodge123 drlodge123 is offline
drlodge123 is starting off with a positive reputation.
Hi,
I have a 2001 4.2l and I am experiencing a somewhat annoying and at times loud vibration/rattle noise from somewhere on the exhaust system.
There was a TSB on this, http://www.ford-trucks.com/tsb/full...php?tsb=03-20-7 .
Did anyone ever figure out what exactly I need to torque, ie. bolts ect?
Also, If I call the local ford dealership and reference this TSB, will they be able to pull it up and then we can go from there?
Thanks
Old 02-22-2007, 07:51 AM
Drizzt's Avatar
Drizzt Drizzt is offline
Drizzt is gaining momentum as a positive member of FTE.
is it a rattling or more of a clunking?
Old 02-22-2007, 10:28 AM
It is definately more of a vibration than a clunk.
Old 02-22-2007, 08:37 PM
G'sRed99F150's Avatar
G'sRed99F150 G'sRed99F150 is offline
G'sRed99F150 is starting off with a positive reputation.
As I understand it, the cat has come apart, mine is starting to do it as well. I don't notice a vibration, but you can definantley hear the rattle.It will drive you nuts, but the only remedy is to replace it. Let us know what you find out for certain.
Old 02-23-2007, 08:00 AM
Drizzt's Avatar
i was definitley thinking the cat as well, but it wouldnt hurt to tighten everything up like in the TSB and see if that helps anything
Old 02-28-2007, 09:51 AM
RTJohnson RTJohnson is offline
RTJohnson is starting off with a positive reputation.
Guys, you need to grab and hold the motor hoist brackets when you hear the rattling. I also thought it was my cats but turned out to be the motor hoist brackets. Yank those damn things and I bet your problem will be gone.
Old 02-28-2007, 05:06 PM
I'll give that a whirl, let yall know something.
Old 03-08-2007, 11:00 AM
SPELLY F150 SPELLY F150 is offline
SPELLY F150 is starting off with a positive reputation.
Check The Part # Tag
I have had the same problem on both of my F150s. I found that the part # tag for the converter came loose and was the source of the noise. After you find out which cat is makin the noise, i split the heat sheild, and I found that the tac welds that hold on the part # tag have broken free. After I was able to yank out the tag the noise was gone. I also have several friends who have had the same problem. All were the part # tag had come loose. It does not take much time, and it does not cost as much as replacin a converter. Its worth a shot to check that first.
PaT
Old 03-12-2007, 05:23 PM
b2_tim b2_tim is offline
b2_tim is starting off with a positive reputation.
RTJohnson, I think you found my rattle, I went out and twanged the engine lift brackets and sure nuf, the driver mount just bounced off the manifold bolt like a tuning fork. Ford didn't bolt it down properly. I ditched it and will test drive tomorrow when cool. Passenger mount still there for now.
Thanks in advance.
Old 08-13-2010, 07:50 PM
Toolman_Koverdog's Avatar
Toolman_Koverdog Toolman_Koverdog is offline
Toolman_Koverdog is starting off with a positive reputation.
Cracked Motor Hoist Bracket is the cause
RT you are a genius! That rattle has been driving me insane. I pulled the CAT heat shield, still made noise. I crawled around under my truck for weeks looking for anything. Tapping with mallet and so forth. Sounded like the rattle was coming from under the truck, but it was that bracket. It cracked and was vibrating like a tuning fork (as b2 tim would say). Thanks for the tip. You may have saved my sanity.
1978 F150 Ranger XLT 78F150RangerXLT 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-22-2009 02:56 PM
3/2/09 Ride Of The Week savage2211 Ride Of The Week 14 03-08-2009 07:52 PM
exhaust leak? stroken 1999 - 2003 7.3L Power Stroke Diesel 4 04-10-2008 07:17 AM
02 7.3 excursion mods list pdx02 1999 - 2003 7.3L Power Stroke Diesel 12 01-23-2008 01:51 PM
Tuner / Programer brettwingfield 6.0L Power Stroke Diesel 4 09-16-2007 10:14 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
03207, 2002, 2003, 2005, 42, 42l, damper, exhaust, f150, muffler, rattle, rattles, rattling, tsb, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
