Envalve - anybody ever use one?
No; that is why you don't want BLOWBY in the crankcase! It's not tiny amount of "unfiltered air" seeping in around old gaskets that is the problem, it's the huge (by comparison) amount of blowby from the cylinders squeezing past the rings that dirty the oil and shorten it's life.
Are you a sales person for this device?
The way the PCV system works is the Positive Crankcase Ventilation (PCV) system cycles crankcase gases back through the engine where they are burned. The PCV valve regulates the amount of ventilating air and blow-by gas to the intake manifold and prevents backfire from traveling into the crankcase. On some engine applications, the PCV system is connected to the evaporative emission system.
Do not remove the normal PCV system from the engine. Removal of the PCV system will adversely affect fuel economy and engine ventilation and result in shorter engine life.
The seals are set up to keep gases or liquid from going out of the engine under pressure (by a spring most of the time). They are not meant to keep what is on the outside out. So as long as you do not have a vacuum in the engine they work as they are designed. With a vacuum they will pull back an open the gap between the crankshaft and the seal. What will come in is large abrasive particles. When these fill up the oil filter the oil filter will go in to bypass and the large abrasive particles will go between all the moving parts or no or little oil will flow.
Ha's going to have to make some vacuum before he sucks anything in or out of that crankcase and it just is not going to happen with this device.
I've challenged him for proof, (vacuum gauge on the crankcase), but all we get is more rhetoric.
I don't know why a forum member for over 10 years with 450+ posts would choose to troll us, but I suspect that is what is happening.
Envalve will suck money out of your wallet, but not fumes out of a crankcase.
sounds like he's being genuine, and has his reasons. and this is nothing new, diesels and carb'd vehicles have had OE systems just like this, systems that pull vacuum on the crankcase...dating back to who knows when. engine builders run pcv straight to vac lines with no pre filter on the other valve cover. doing a conventional setup would be a massive vacuum leak ...
props to the guy for speakin his mind. 58 bucks for a glorified pcv system it is, and functional for those who don't know the difference.
for the record, I wouldn't own one. but there are some situations where I'd pull vac on the crankcase, and more situations that I wouldn't.
I have not seen any OE systems or read about any OE systems that pulled a vacuum on the crankcase.
Also every OE PCV system I have seen had a filter on the air going into the crankcase.
You do not understand how seals and a normal PCV system works do you?
"With a vacuum they will pull back an open the gap between the crankshaft and the seal."
No, 6 inches of vacuum will not cause your seals to fail.
"The seals are set up to keep gases or liquid from going out of the engine under pressure (by a spring most of the time). They are not meant to keep what is on the outside out. "
No, your engine gaskets are not 1 way seals. The crankcase is not supposed to be pressurized, but that happens when an engine gets old.
"Removal of the PCV system will adversely affect fuel economy"
No, it won't. It is an emissions control device and reduces fuel economy. As is the envalve.
".. and engine ventilation and result in shorter engine life."
Keeping the crankcase clean does help the engine live longer, but the point is that at some point, the PCV valve has lost it's effectiveness because it can't keep up with the blowby in a worn engine. So this is a step up from that.
I don't think the auto manufacturers see it as something worth spending the extra money on, since it's not really offering much of an improvement until late in the life of the engine.
#28
Absolutely I need a rebuild. No argument there. But it is nice to be able to use the truck for almost 2 years now without having to put that $$ into it.
#29
Easy one. 6.9, 7.3. Granted, NA they don't generate the vacuum a throttle body equipped gasser does...they def generate vac turbod and the system doesn't change. That's one that comes to mind....
#30
Cracker289,
Sorry but what I posted in post #18 above was quotes right out of the Ford shop manual. Maybe you should tell the Ford engineers how all of this works.
Maybe I should have noted that.
Jim,
Yes I had a road draft tubes on about 5 of my Fords from 1951-1959. Not sure if my 1966 had on or not. There was a filter above the tube that hung down and also the cap where you put the oil in the rocker cover had an oil impregnated mesh to filter the air going into the engine.
When I was out in S.D. California in the Navy in 1961 they passed the PCV law and I had to take my 1956 312 into a muffler shop have a hole punched in the rocker arm cover for the PCV valve. It seems like the hose from the PCV valve went to the air cleaner. They caped off the road draft tube as I recall. I am not sure if that was a valve or just a hose running to the air cleaner.
Jim,
