dash bezel and cluster screws are stripped
My 79 F-150 is being quite a bear. Why did Ford change out perfectly functional screws to rivets? - Oh sorry, off topic.
Anyway, I tried to remove the dash bezel to get to the instrument cluster and half of the screws were stripped. I ended up breaking the bezel, cutting off one of the screws, and prying off 2 other ones. Now, I am experiencing the same problem with the instrument cluster screws. But I would prefer not to break the instrument cluster if possible.
I already have an extra dash bezel to replace the busted one, but I need to locate new screws and fasteners (not sure what they are called). Also, should I start shopping for a new instrument cluster or can the existing one be removed safely?
If you need to know, my dash lights are out and part of the reason is that I've had a couple bulbs come off. I wanted to make sure the circuit board is okay. Another off-topic question: will the circuit board (or entire instrument cluster) from a 73 fit a 79?
on
Good news is you can use the cluster out of an Econoline van. I believe that the 1978 to 1984 Econolines are a direct swap. While the others between 1975 to 1991 you will have to use your old printed circut on the newer cluster back. Try to get the cluster back with the number that starts with "E1TF". (not the printed circut, the actual white back that the printed circut bolts to.) Those are made of better plastic and are less likely to "rot".
Hop0e this helps...
You could always take a drill bit a little smaller than the head to drill the head of the screw off, take off what you need and then get the rest of the screw out. May end up drilling the rest of the screw out and ruining your clip, but its better to ruin a screw and clip than a cluster or bezel. I think that's why many bezels get busted out in the salvage yards because the screws get stripped or rusted and people just break the bezels to get them out. I found a nice wood grain bezel, no wear and tear, but it was busted in half laying on the seat. Looked exactly what you described, couldn't get the screws out so they busted it. Anyway, at least you have another bezel. If your cluster gets busted also, not to worry too much, they are a dime and a dozen in salvage yards and on ebay.
To answer Mil1ion's question about which ones - for the bezel, it doesn't really matter now because I've torn everything all to *, I doubt even the retainers are useful anymore. As far as the cluster, I was able to remove the top left screw, and the other 3 spin in place.
Originally for the bezel, I had tried a flat head screwdriver under the head of the screw to pull on it a little (to no avail) but I can see where the C-pliers would work better. I'll give that a shot.
About cluster rot - bummer. The front of the cluster looks pristine, just a couple marks on the plastic cover and a little fading on some of the orange meters.
Not looking forward to drilling out the screws (if the C-pliers don't work), but if that's what it takes to get the cluster out, then so be it. And I guess I'll be calling my local yards.
Thanks for the help.
on
Check around the "light holes" for this "crumbling" plastic rot. It may only be in it's early stages, and that's why the bulbs fell out etc...
Here are the two Ford updated part numbered cluster backs that Ford uses on F100/350 1975/79. The printed circuit is not included.
E1PZ-10848-A Instrument Cluster Back Plate-use with gauges
E1PZ-10848-B Instrument Cluster Back Plate-use with lights.
Even though the dash on the F Series trucks changed in 1980, the Econolines did not. E150/350's continued to use the same back plate for several years.
These plates may still be available from Ford.
Please note: I said updated part numbers, something Ford does frequently. I don't want anyone here having a hissy fit over the fact the numbers reflect a newer model than the years they replaced.
on
Just like to add that these are the ones made of the better plastic as well. The only difference between the "D5's" and the "E1's" is the plastic they are made of.
Also if you get these at the wrecker the engineering code on the back will either start with a E1PF or E1TF (I forget which now. ) An Engineering number is different than a Part number.
hope this helps...
Not Fragile
04-27-2023 01:55 PM
Shadowrider123
11-15-2014 09:18 PM
LARIAT 85
08-15-2012 06:20 PM
