Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-11-2002, 08:15 PM
bronco cam bronco cam is offline
bronco cam is starting off with a positive reputation.
after market fuel pump
I guess my fuel pump needs replacing. I am running about 25 pounds of pressure.When I give it gas it drops in pressure.My question is is there a after market fuel pump? Does someone like holley or eldlebrock make a in tank fuel pump. Are they higher volume? Does a high volume realy help or is it just a waste of money.
__________________
When in doubt apply throttle!
  #2 (permalink)
Old 10-11-2002, 10:18 PM
mudbug79 mudbug79 is offline
mudbug79 is starting off with a positive reputation.
[updated:LAST EDITED ON 11-Oct-02 AT 10:19 PM (EST)]I swear by my Carter 72Gph electric pump.Feeds my 472Ci with no problem.Yes,High volume pumps are worth while.
  #3 (permalink)
Old 10-11-2002, 10:23 PM
Sounds like your running just a few more horse power then i am Does anyone out there use a higher volume fuel pump for stock motors such as a 96 351? I need to replace my in tank fuel pump so I thought if there is something aftermarket I would upgrade.
__________________
  #4 (permalink)
Old 10-16-2002, 09:42 PM
heybrent heybrent is offline
heybrent is starting off with a positive reputation.
I went from a manual to electric inline fuel pump (universal from Auto Zone) and it works wonderfully. Never had a problem with it and it wasn't expensive. Might try that until you get the one you really want.
__________________
Brent Smith
"Silver Beast" has been put down
Now I have an 89 Eddie B
  #5 (permalink)
Old 10-17-2002, 01:08 AM
Hwy Apostle's Avatar
Hwy Apostle Hwy Apostle is offline
Hwy Apostle is starting off with a positive reputation.
  #6 (permalink)
Old 11-02-2009, 09:53 PM
v8xploder's Avatar
v8xploder v8xploder is offline
v8xploder is starting off with a positive reputation.
I try my best to stick with Ford OEM stuff on my stock vehicles anyway..
But I am in the same boat and need to replace my fuel pump and a Ford OEM for my 1992 is 450 dollars and they said I need a 37 dollar jumper wire, for what I do not know but that is outrageous.
What brand did you end up going with? like? dislikes?
__________________
Cody
69 Bronco, 351W, Edelbrock performer, Holley 670 T/A 35'S 5.5'' Wildhorses lift, Locker rear, F-100 power steering and a slight rear main leak
92 Bronco Eddie Bauer, 351w, 31x10.50 No rust!!!
  #7 (permalink)
Old 11-03-2009, 12:34 AM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
Rockauto has a good selection. I might be going with the 47 dollar version that requires the existing parts to be reused and only the pump is replaced.
  #8 (permalink)
Old 11-07-2009, 09:50 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 is starting off with a positive reputation.
im not sure when they stopped using them, but elder efi trucks had a low pressure in the tank and a high pressure on the frame. if yours is an in tank high pressure pump, i would look into a pump for a mustang, if not there are a couple of aftermarket efi pump for the frame, but they are not cheap, 250 and up and you would still need to figure out how to adapt it in.
__________________
1973 f250 highboy 4x4
1984 full size bronco, megasquirted 300 on the way!
1988 f150 extended cab 4x4
1984 mercury capri, 5.0 conversion
1961 ford falcon, all stock, in family since '68
  #9 (permalink)
Old 11-08-2009, 12:25 AM
g_k50's Avatar
1990 Ford Bronco
My Garage
My 1990 Bronco has the one pump in the tank, low and high pressure both in tank, fuel filter on the frame under the drivers door.
  #10 (permalink)
Old 11-08-2009, 12:58 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
1989 was the last year for dual stage pumps on these trucks. I have looked and have not found an aftermarket pump that fits inside the resovoir on these trucks, the high volume mustang pumps are all longer and don't fit.
The pump itself can be purchased online pretty cheap($50) and swapped into your existing FDM...
Or you can also buy a complete FDM($80) and simply swap the hard lines over..
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #11 (permalink)
Old 11-08-2009, 04:26 PM
Encho's Avatar
Encho Encho is offline
Encho is starting off with a positive reputation.
Hey Conanski... my pump just died on me yesterday (after eleven years of faithful service, almost doubling the time of the original one). If i intend to switch the pump myself what am i getting into? what will i need to do it? Any pointers and recomendations?.
I know i'll have to take down the tank, how many bolts or nuts are there? where are they in general (haven't inspected yet)?.
__________________
1993 Special Edition Bronco (EB equivalent)
5.0lt V8, E4OD Auto
Member of the International Chapter
Tags
1990 , 93 , aftermarket , bronco , complete , ford , fuel , good , market , oem , pump , pumps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
