Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-21-2007, 12:09 PM
87hurricane is starting off with a positive reputation.
Cold Idle Issues
I have a 90 Bronco with a 351, it has always run fine for me, but about a week ago, I had the battery disconnected for an extended period of time, and now it won't idle when its cold. It starts fine, but when it idles down slightly it begins surging, and then stalls. The only way to keep it running is to hold the idle higher with the throttle. Once its warm it runs just fine, but it has kicked on the check engine light a couple times when I'm coasting at highway speeds. I pulled the codes, and I get a 11 KOEO code, and a 41 continuous code. No codes while the engine is running, I'm not sure if I'm doing that test right. I could really use some help folks, I'm a little lost as to what I need to do next. Thanks in advance guys.
Dave
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-22-2007, 01:01 AM
96eddie5.8 is starting off with a positive reputation.
i had the same idle and surge problem when it was cold out. i forgot what it is called. IC something, but its right where the intake meets the engine, it has a piston which lets more or less air into the engine. piston was shot. plus my pops ripped the solenoid out. hope it helps maybe.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
