76 F100 360 Wont start.. again!
Well. I have a 76 F-100 short <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1:address w:st="on"><st1:Street w:st="on">Box</st1:Street> 4x4</st1:address> 360 4 speed manual transition.
It wont start. I did the timing gears / chain on it a couple of weeks ago.
The truck ran great for about a week. Now the truck won’t start. Cranks over but will not fire. I have spark, I have fuel, I have air (I assume the air filter is off). I have compression. The timing is set at 12 degrees BTDC. I am guessing at this since I cant get it started I cranked it to where the rotor was pointing at the number 1 cylinder contact and read the reading on the vibration damper. If any one knows what the correct setting for this truck is I would greatly appreciate it. Manual says to check emissions sticker under the hood. Its long gone!
The carburetor was replaced the same time the timing chain was done. It has a new coil, new fuel pump, new ignition switch.
It cranks fine just wont fire. I’m at a loss.
Sounds to me like the ignition module/pickup coil in the dizzy. Did you replace those before, and if so, with what..rebuilt units? Those DuraSpark units are mis-named. NeverSpark would be better. They were crappy and unreliable in the 70's and are now worse. Go with a modern electronic ignition system.
on
Check yer plugs and see if they are wet. Like Bill said. It may have spark, Just not enough to fire the wet plugs under compression. I have seen this meny times. Replacing the plugs may work for a week or two than the same problem again.
Also you said that with the rotor pointing at number one you had 12*BTDC. It should be at 0 TDC. And only advance when running. So yer timming is off I would think.
