Transmission fluid change, how much? - Ford Truck Enthusiasts Forums
Old 02-21-2007, 07:44 AM
fordtruckman's Avatar
fordtruckman fordtruckman is offline
fordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to beholdfordtruckman is a splendid one to behold
Question Transmission fluid change, how much?
I have plowed quite a bit this year and since i have plowed so much i wanna get my trans fluid changed, how much will the dealer charge to get it changed, also any other fluids that may have to be changed from prolong periods of plowing?
Old 02-21-2007, 09:27 AM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
Trans flush/fill service is ~$130 in my area.
Maybe change the transfer case too since it's Mercon also?
Old 02-21-2007, 10:54 AM
AB328 AB328 is offline
AB328 is starting off with a positive reputation.
Question
Anyone know if Ford rates the tranny fluid up to 100,000??
Old 02-21-2007, 11:39 AM
gui88ford's Avatar
gui88ford gui88ford is offline
gui88ford is starting off with a positive reputation.
i'd say to look in your book and follow that....should give you an amount of miles when the tranny is supposed to be flushed and re-filled...
they actually have a pump at the garage and they hook that to your truck then just pump the old out and put the new in.....it's pretty quick and usually around 100 to 130 bucks...
KevinM KevinM is offline
KevinM is starting off with a positive reputation.
The 5.4 tranny fluid is considered lifetime, not sure if I believe that. Not sure what the 4.6 calls for. Flush is $132 in my neck of the woods, but a flush does not replace the filter, it does get the fluid out of the torque convertor. So maybe a flush the first time around and a filter change on the next one will surfice.
Old 02-21-2007, 11:57 AM
VFR_Man's Avatar
Lifetime, really? Yikes. The only application I'd trust any ATF for lifetime would be sitting on a shelf in a hermetically sealed glass jar.
Old 02-21-2007, 11:59 AM
gui88ford's Avatar
Quote:
ha-ha-ha, yeah thats about it.....
my suggestion would be to as a mechanic of find one on here that will give you a strait answer...
Old 02-21-2007, 12:30 PM
Don't believe me go read the manual it's lifetime on the 5.4 transmission. That's where I got it from. Doesn't anyone read the book!
I wouldn't trust a mechanic either. Lots of them still state to change your engine oil every 3,000miles.
ENHANCED AUTOMATIC TRANSMISSIONS
Matched to the new 5.4-liter V-8 is a new 4R75E automatic transmission, an evolution of the 4R70E used on the current F-150. Upgraded to handle the torque of the 5.4-liter engine, this transmission shares patented upgrades with the 4R70E, which backs the 4.6-liter V-8:
  • A redesigned torque converter improves launch performance and increases efficiency.
  • A turbine speed sensor improves transmission control, providing the basis for fully electronic shift scheduling to limit "hunting" and to fine-tune shift speed and feel.
  • Increased microprocessor speed improves responsiveness and precision of the control system.
  • "Smart" fully electronic shift scheduling knows what the torque will be in the next gear so it chooses the shift points based on the vehicle's projected performance in the next gear.
  • Coupled with the electronic throttle strategy, the transmission computes the output torque required to maintain the vehicle speed, and chooses the correct gear and converter state accordingly.
  • A sealed case and lifetime transmission fluid make the transmission maintenance free, while adaptive pressure control maintains consistent shift feel over time.
By predicting the performance of the truck in the next gear, the computer-controlled transmissions provide a more sophisticated solution to heavy demands than a simple shift delay switch, such as the one-size-fits-all "towing mode" some competitors use.
Old 02-21-2007, 12:59 PM
gui88ford's Avatar
cool....i'd still ask a mechanic...(that you know) what he thinks....
Old 02-21-2007, 03:25 PM
4DOORSR 4DOORSR is offline
4DOORSR is starting off with a positive reputation.
How about pulling out the dip stick and actually checking the fluid? If it smells burnt or looks discolored then change it. If not, leave it be.
Old 02-21-2007, 03:29 PM
gui88ford's Avatar
thats a good idea also....hopefully it doesn't smell burnt....
Old 02-21-2007, 06:00 PM
04 FX4 Lineman 04 FX4 Lineman is offline
04 FX4 Lineman is starting off with a positive reputation.
I don't know how ford could call this a selaed case when it has a dip stick not very sealed IMO, most ford techs will recommend every 30K or so if you are doing any towing.
Old 02-21-2007, 09:57 PM
F150 Dude F150 Dude is offline
F150 Dude is starting off with a positive reputation.
Do your self a favor and change it every 20 thousand, I always do and it works for me, they only do the flush now , depending on where you live it should be below 150 bucks for the flush, If Im rite the book says at 20 thousand it should be changed to keep up with the warranty ! but what do I know ? Check your book..
Old 02-22-2007, 09:58 AM
The reason Ford can claim lifetime fluid is the spec on the transmission fluid now is much better then in the past, It's a part synthetic and has much better additive package for longevity.
I would say every 20K is a little excessive in today's world! The owners manual makes no 20K claim on the 5.4 trans.
Old 02-22-2007, 10:12 AM
bsocko bsocko is offline
bsocko is starting off with a positive reputation.
Quote:
Where did you get the info from? Your service manual recommends changing it every 30,000!
Plow FordTruckGuy96 1987 - 1996 F150 & Larger F-Series Trucks 6 02-28-2015 09:10 AM
2014 SD and a Plow JoeP53521 1999 to 2016 Super Duty 20 04-09-2014 08:46 PM
C6 shifting late all of the sudden zspeed130 1987 - 1996 F150 & Larger F-Series Trucks 4 06-22-2013 06:21 PM
To plow or not to plow Sgt93 6.7L Power Stroke Diesel 19 02-04-2011 07:39 PM
How do you make money snow plowing? Gmeanie 1999 to 2016 Super Duty 17 11-08-2008 06:55 PM
Tags
04, 6r60, 94, add, automatic, change, edge, f150, fluid, flush, ford, maintenance, oil, scheduled, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
