The best Coolant & Spark Plugs For 5.4L? - Ford Truck Enthusiasts Forums
Old 02-20-2007, 08:40 PM
Fredster Fredster is offline
Fredster is starting off with a positive reputation.
I have a 2000 F-150 4X4. Its almost at 100,000 Miles. What is the best Spark plugs and the best Coolant to use? I also want to flush my cooling system also. Is there a better coolant for alum. heads? And should I use single platinum or double platinum plugs? My manual says to use AWSD-22E Plugs, which I assume those are Motorcraft. But I am not sure if they are single or double platinum?
Old 02-20-2007, 08:45 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
If that is what the manual says, I'd stick with it. I think there is an Autolite plug that is comparable to the Motorcrafts for a cheaper price. As for coolant, I went with Walmart brand Supertech and mixed it myself 60/40 strength with distilled water, I think it works just as well as the expensive Motorcraft stuff. Just my 2 cents.
Old 02-20-2007, 09:18 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I used the Prestone for all vehicles in my truck. Yes use distilled water if possible. It will reduce electrolosis in the cooling system. Double platinum plugs work best. Use Motorcraft or Autolite.
Old 02-20-2007, 09:30 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
stick with the Motocraft plugs. never have a problem. other brands dont play well with some of the 5.4 V8 motors. as for antifreeze, i think the cheaper Wal Mart brand is fine. its all the same anyway.
Old 02-20-2007, 09:59 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Just make sure you put the same color of coolant back in. Motorcraft or autolite plugs, whichever are cheaper, they are the same thing. that number you have is superseded with a new number I am sure.
New Double Platinum Plugs and Wires saintthomas 3.0L V6 79 12-14-2014 08:25 AM
Double Platinum Spark Plugs little_mule Modular V8 (4.6L, 5.4L) 3 05-05-2012 09:01 AM
Spark Plug Mini Tutorial pawpaw Ranger & B-Series 0 11-22-2011 02:39 PM
Spark Plugs- Motorcraft or Autolite JTD1972 1997-2006 Expedition & Navigator 10 06-03-2006 04:30 AM
Spark plugs for 92 Explorer JTD1972 Explorer, Sport Trac, Mountaineer & Aviator 2 11-19-2003 04:20 PM
Tags
2003, 54, 54l, antifreeze, brand, coolant, draining, f150, f250, ford, plugs, price, rating, spark, supertech, walmart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
