stock 302 max rpm/horsepower
02-20-2007, 07:46 PM
on
what is the max amount of rpms/horsepower can a 302 handle with the stock bottom end, and what are some weak points that could be upgraded to make it stronger?
02-20-2007, 10:35 PM
Guys are approaching 500hp with NOS and blowers on 5.0 HO's no problems. The only difference internally between the HO and truck short blocks is forged pistons and better cams in the HO motors.
02-21-2007, 04:24 PM
on
ok, so what kind of rpm's are they turning without it coming apart?
02-21-2007, 07:50 PM
on
Stock bottom end, your good to 5800-6000 rpm.
02-22-2007, 01:25 AM
on
if you going to spin them past 6000 you need rod bolts
newguy399
05-28-2017 05:12 PM
Blown 331
12-24-2009 04:57 PM
OrangeJuice
09-23-2009 11:03 PM
nflfreak43
22
12-02-2008 06:20 PM
lilpig88
05-30-2003 07:18 PM
1986,
302,
bronco,
early,
ford,
handel,
ho,
horse,
max,
peak,
power,
rpm,
sock,
stock,
v8
