anyone out there who has used one of these march performance serpentine pulley/bracket conversion kits on their 95' 5.0l f-series motor? please let me know. i need to know if one of these kits will work on my bronco motor and march performance gives me a different answer every time i call.
march part # 30127 for use with saginaw p/s pump. it includes all brackets and pulleys. that is all i can tell from summits description. i am assuming it is an underdrive kit. is there anyone who has used this part# number or part #30125 on there 95 bronco or f150?
a 95 already runs a serp setup. so im not following you. if your wanting to run underdrive setup i suggest not doing so. not much gain and your cooling and alt will not like it.
i did drop march performance. i ended up with an entire 93' mustang bracket and pulley kit. 93 mustang ac eliminator. ditched the smog pump,added a milodan 16234 water pump, then sent the 93 ps bracket and pulley to psc power steering. they are fabbing the bracket up to accept the saginaw pump i needed (remote reservoir style) and boring the pulley out.thank god this is over with
psc is doing all the custom work on the bracket and boring the pulley for free. the bracket kit was $150. the power steering bracket on the 95 f-series is a giant turd, and the 93' stang bracket is much easier to deploy saginaw or tc style. this is not for a bronco. it is a 2007 mid engine xrra rock racer. ford racing agrees with me on the route i took (not that it was pricey) being the easiest way to go.thanks for the help with this though
