Heater Issue - 1978 F150 4X4
Ok, I am new to the forum. I have a 1978 F150 4X4, 400 2bbl.
Air blowing out of defrost or floor vents never gets warm until the weather warms up some. Have pulled heater hoses and blown air through the heater core. Seems to have no restrictions. Engine temp appears fine. I have a 195 degree t-stat and have blocked the radiator by about 2/3. I have also taken the fan shroud off in an attempt to force the engine to run hotter so I can get some warm air in the cab. All to no avail.
Any ideas?
I ahve been freezing my butt off for the past few weeks in Michigan.
Any ideas?
welcome to the site!
check to make sure the heat control door in the heater box is adjusted correctly and not letting cold air past the heater core. Even though you say you cleaned the heater core it may still be plugged enough to slow the heat down. I live in Michigan too, I had the same problems a few months ago, and after I replaced the core it was better than it had been in years.
Joel
Joel
The only thing from the Ford heater trouble-shooting guide that hasn't been done or mentioned by you is :
Check cowl,Vent,air ducts for adjustment and/or air leaks (if applicable)
That's the last item in this guide.
NOTE: at normal operating temp the heater hoses (BOTH) can NOT be held on to for very long without burning ones hand.
are yours this hot ?
Some of the standpipe adapters on the intake manifold where the heater hose clamps on, have a shutoff valve on top like a kitchen faucet. Turned all the way in will shut off the water to the heater core. Hoses won't get warm because water can't flow through them. Rust can clog them inside too.
And then there's the dreaded Ranco Valve aka heater water control valve. Those damn things leaked, and also stuck closed. You can slide the lever on the dash back and forth till doomsday, and nothing will happen, because the mechanism on the valve is shot.
Heater Hose Temp
I can hold the hoses as long as I choose. So, apparently the flow is limited. I guess I will pull the hoses and heater core and check for restrictions of any type. I will also verify that there is no restiction from sediment/rust at the nipple in both the block and the water pump.
Thansk to everybody for helping. I will let you know how it turns out.
68 351 bronc
09-30-2011 05:57 PM
oldstylefseries
03-18-2005 09:19 AM
